AMA event- Migrating Existing Networks to Cisco ACI
1114
Beginner
UCS and ESXi 5.5
Hi UCS Users!
We run ESXi 5.1 on UCS B200 and B230 and it works great-
We're about to build out our first ESXi 5.5 cluster and I am just wondering if there are any issue with ESXi 5.5 on UCS that anyone has run into?
I know it's a broad question, but you never know.
Thanks!
1 ACCEPTED SOLUTION
Enthusiast
Re: UCS and ESXi 5.5
Please check the Hardware and Software Interoperability Matrix:Cisco Unified Computing System - Technical References - Cisco
Here's the latest:
http://www.cisco.com/c/dam/en/us/td/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel2-21.pdf
Check your Virtual Interface Card or adapter to make sure you're in a support configuration!
NB: AFAIK,  the Palo/M81KR certification is in process, but expected soon.
1 REPLY 1
Enthusiast
Here's the latest:
Content for Community-Ad
August's Community Spotlight Awards
