03-20-2018 06:49 AM - edited 03-01-2019 01:27 PM
we use SD cards in our B200 M3 servers. Unfortunately I do not know how to format them.
I tried several ways:
- the option "Format SD Cards" is shown grayed out in the Inventory -> Storage -> Controller Tab
- Scrub Policy with "FlexFlash Scrub"enabled does not scrub the cards
- there is no BIOS/Controller Menu to format them directly
We are using a Cypress FlexFlash Controller, running version 1.2 build 258-2.
Does anyone know this problem and is there a way to format SD cards from UCSM?
This works perfect with B200 M4 and M5 server.
Martin
Solved! Go to Solution.
03-20-2018 06:53 AM
The older flexflash controllers in B200-M3 do not allow for format via GUI.
You need to create a Flex scrub policy, enable flex scrub and then re-ack the blade, which should scrub the SD cards.
• For an associated server, create a FlexFlash scrub policy and disassociate the service profile from the server. For an unassociated server, create a FlexFlash scrub policy and reacknowledge the server after modifying the default scrub policy. The Scrub Policy Settings section in the Cisco UCS Manager Server Management Guide provides more details about the usage of the scrub policy
03-20-2018 06:53 AM
03-20-2018 08:42 AM
Hi Wes,
thanks for the fast reply! I did some tests according to your advice and (only) the following did the trick:
1. disassociate any service profile, the server must be unassociated
2. set "FlexFlash Scrub" to "Yes" for default Scrub Policy
3. Re-Acknowledge the server
Afterwards the SD Cards are deleted.
05-31-2018 07:03 AM
05-31-2018 07:22 AM
1)
2)
Release Notes for 3.2 under “Behavior Changes and Known Limitations”
“CSCve53092—For a server associated with a service profile, disk scrub and FlexFlash scrub occur during disassociation, based on the scrub policy used in the service profile.
For an un-associated server, disk scrub and FlexFlash scrub occur during the server discovery
process, based on the default scrub policy.”
05-31-2018 07:43 AM
05-31-2018 11:28 AM
05-31-2018 11:10 PM
I just did a flex flash scrub of a M3 server via a re-acknowledge and the default scrub policy, still works for me.
Which firmware version are you using? Our UCSM is currently running on 3.2(3a).
06-01-2018 05:03 AM
06-01-2018 07:00 AM
"Firmware is at 3.2(3a), UCS "acts" like it will scrub the Cards, but in the FSM reads out that it Skips that task.
This is correct and great catch by looking at FSM skipping that task.
Re-Ack of the blade does not scrub the FlexFlash SD Cards as you have seen.
This is expected behavior in newer 3.2.x code where Re-Ack will NOT scrub the SD card.
Scrub policy behavior is changed via CSCve53092 to make it consistent across Blade & Rack platforms.
This new behavior is actually documented in the 3.2 Release Notes:
CSCve53092—For a server associated with a service profile, disk scrub and FlexFlash scrub occur during disassociation, based on the scrub policy used in the service profile. For an un-associated server, disk scrub and FlexFlash scrub occur during the server discovery process, based on the default scrub policy
Carlos
