If you loose one FI, you can replace it by going through the following procedure
- update the replacement FI to have the same firmware version as the peer FI (otherwise the cluster will not be built)
- erase configuration of the replacement FI, and connect cluster heartbeat to good FI
- Terminal session to replacement FI: asked to join a cluster, enter admin pw, configure out of band IP for replacement FI
- cluster will be built, and synch of configuration replicated to replaced FI.
However, you would probably like to have a backup, for the case you loose both FI's ?
This is well documented in
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/2-2/b_UCSM_GUI_Configuration_Guide_2_2/b_UCSM_GUI_Configuration_Guide_2_1_chapter_0101001.html
