UCS-C Series KVM Issue
Hi all,
I have a UCS-C 220 Firmware versión: 1.5b, the server is new and clear.
So I tried to use a KVM to start the configuration, but the KVM never start.
I have a IE 11 and the last version of Java.
We've tried other versions of Java and Internet Explorer, plus disable the windows firewall and add exceptions of security to server´s ip in settings of java.
Any idea?
venkatevt
Try using older Java version may be Java 6....
I tested with other versions  the Java and Internet Explorer, is the same.
Jeffrey Foster
Hi Rene,
Are you seeing any downloads or pop-up's when you launch a KVM session? I find that this sometimes opens behind the open window and will timeout before I realize it. Depending on which browser you use, you may need to associate the downloaded .jnlp file with Java prior to getting prompt to accept this session.
Jeff
Hi Rene,
I to have many issues with the KVM system of the UCS.  The thing that will solved most of them for me is to flush the Java cache (temporary internet files ) in the control panel java applet.  You may also remove all the install java apps and just run one version of it.  Also make sure that in network setting your using Direct connection and not browser settings.
Good luck
regard's
Stephane
Stephane Beausoleil
virtualisation architect
CGI
