UCS C series maximum hard drive size
jebyers
Looking for info on the maximum hard drive size support on teh UCS C series.  I have a C200M2 that I added a 4TB drive, I have updated the server to the latest firmware and BIOS however the server shows the drive size is 2TB.
Keny Perez
Level 8
Level 8
Hi!  and welcome to the community mate!
Here is the table that shows the supported disk's PID for the C200 server:
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c200m2_sff_specsheet.pdf
If you successfully installed ONE HDD of 4GB and made it work, you were lucky cause I don't see any disk with that size, I have not even seen a disk of that size for UCS yet.
I am wondering if perhaps you installed 4 disks of 1TB and configured them in RAID 1 which would explain the reason for the size to go down to half of the capacity of the array as RAID 1 is a mirror.
Let me know if I misunderstood you.
Rate ALL helpful answers.
-Kenny
Clifford Aldan
Can you clarify a few things
1. What RAID level is this 4TB drive set up for?
- What size and speed are the hard drives? (1 TB 7.2k RPM SATA, 300 GB 10k RPM SAS)
- How many drives are installed in the C200?
2. What RAID controller is installed on the server?
3. What do you mean by "server" here?
- UCS CIMC showing 2 TB?
- Operating system showing 2 TB?
4. What operating system is installed on the server?
