Field Notice 70545
852
jbeaulau
UCS C200 DIMM compatibility
I have 15 UCS C200 platforms that I need for lab use, and need to populate all 12 DIMMS slots
in each with 8GB DIMMS. All but one DIMM part number in CCW have been EOL'd. The remaining
DIMM that I see when I search with "UCS C200" is part number UCS-MR-2X082RY-B=. When I Google
this part number it calls out for a B250 or B260 blade server. Can these DIMM's be used in a C200 chassis?
-John
4 REPLIES 4
sachinga.hcl
Enthusiast
This product has been discontinued.
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c200m2_lff_specsheet.pdf
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-c-series-rack-servers/c200m2_sff_specsheet.pdf
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C200M1/install/c200M1/replace.html#18345
Best Regards
Sachin Garg
Hi Sachin,
Yes, the chassis is EOL, but I need to use the ones I have, and need to outfit with more memory for the lab use they're going to be repurposed for. Do you know if DIMM part number UCS-MR-2X082RY-B= will work? They are DDR3 so I don't see why they wouldn't.
-John
I think UCS-MR-2X082RY-B= is not compatible with UCS C200:
Check below:
http://www.cdw.com/shop/products/Cisco-DDR3-16-GB-2-x-8-GB-DIMM-240-pin/3470266.aspx
UCS-MR-2X082RY-B= is only  Compatible With:
Cisco UCS B250 M2 Extended Memory Blade Server
Cisco UCS C250 M2 Extended-Memory Rack-Mount Server
Cisco - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
Mfg. Part: UCS-MR-2X082RY-B=|CDW Part: 3470266|UNSPSC: 43201402
  • DDR3
  • 16 GB : 2 x 8 GB
  • DIMM 240-pin
  • 1600 MHz / PC3-12800
  • 1.35 / 1.5 V
  • registered
  • ECC
  • for UCS B250 M2 Extended Memory Blade Server
  • C250 M2 Extended-Memory Rack-Mount Server
Availability:6-8 days
Orders placed today will ship within 8 days
$484.99CallAdvertised Price
This item is currently unavailable to purchase online. Please contact us to place this order.
Sales Assistance
800.800.4239 Mon-Fri 7am-7:30pm CT
Answer within 24 hours.
Lease Option ($15.13 /month) Lease Availability
Product Overview
Main Features
  • DDR3
  • 16 GB : 2 x 8 GB
  • DIMM 240-pin
  • 1.35 / 1.5 V
  • registered
  • ECC
Technical Specifications
Specifications are provided by the manufacturer. Refer to the manufacturer for an explanation of the print speed and other ratings.
 Header
 Brand: Cisco
 Compatibility: PC
 Manufacturer: CISCO DS HARDWARE DIRECT
 Packaged Quantity: 1
 Product Line: Cisco
 Miscellaneous
 OEM Manufacturer Equivalent Part Number: Cisco UCS-MR-2X082RY-B
 RAM
 Chips Organization: X4
 Data Integrity Check: ECC
 Form Factor: DIMM 240-pin
 Memory Specification Compliance: PC3-12800
 Memory Speed: 1600 MHz
 RAM Features: Dual rank , Low Voltage
 Registered or Buffered: Registered
 Storage Capacity: 16 GB
 Supply Voltage: 1.35 / 1.5 V
 Technology: DDR3 SDRAM
 Type: DRAM
 Upgrade Type: System specific
 Memory Module
 Capacity of Module in Kit: 8 GB
 Modules in Kit: 2
 Miscellaneous (CDW)
 Compatible With:
Please rate if you find this information useful to you.
Best Regards
Sachin Garg
Best Regards
Sachin Garg
Content for Community-Ad
