Cisco Community Designated VIP Class of 2020
656
Beginner
UCS C210 m2 low IOPS
i currently have a case for this with cisco but i thought i would post to the community to seek any advise...
I have 2 ucs c210 servers,
Both are almost identical.
Ucs1 - Has 24 threads of CPU power and 32gb ram,
Ucs2 - has 16 threads of CPU and 48gb ram.
Other then that both have identical server os - win2k8 r2 running hyperv
Same raid configuration and same hard disks.
Ucs 1 is getting significantly higher IOPS
This becomes ever more clearer when benchmarking a guest server.
Attached is benchmarks of guest on each server (migrated server)
I have swapped out the raid card under wty with Cisco, however performance was not improved.
So..
Any other thoughts as to the big performance difference?
Could it Be a windows setting somewhere a I've missed?
Or is a a mainboard or other hardware fault?
1 ACCEPTED SOLUTION
Hi Robert,
Thanks for the update
Performance decreases in Windows Server 2008 R2 when the Hyper-V role is installed on a computer that uses Intel Westmere or Sandy Bridge processors
http://support.microsoft.com/kb/2517329
4 REPLIES 4
Antivirus off on both servers or exclusions set for the files/directory the tool is using?
NTFS cluster sizes and alignment the same on both servers?
Beginner
No AV on the host server
NTFS is default settings
same RAID config on both servers. - just installed brand new disks and setup exact same raid on each host. no load on this new virtual disk.
Beginner
This ended up being a Microsoft Hyper-V issue and > 32GB ram.
There was a hotfix for this, however it appears that the hotfix has been rolled into the lastest updates for w2k8r2.
Hi Robert,
Content for Community-Ad
FusionCharts will render here
