I have a problem with C210 M2 with 2 PCIe HBA. The problem is OS (RHEV) report with error log about the Problem with HBA card (Fibre Channel Traffic Disruption) cannot connect with FC Storage
When I get the log from SEL.
Time Severity Description
2011-09-13 16:24:43 Normal "BIOS_POST_CMPLT: Presence sensor, Device Inserted / Device Present was asserted"
2011-09-13 16:24:42 Normal "System Software event: System Event sensor, OEM System Boot Event was asserted"
2011-09-13 16:23:07 Normal "System Software event: System Event sensor, Timestamp Clock Synch (second of pair) was asserted"
2011-09-13 16:23:35 Normal "System Software event: System Event sensor, Timestamp Clock Synch (first of pair) was asserted"
2011-09-13 16:23:11 Informational "LED_HLTH_STATUS: Platform sensor, FAST BLINK event was asserted"
2011-09-13 16:23:11 Normal "BIOS_POST_CMPLT: Presence sensor, Device Removed / Device Absent was asserted"
Where I can find the document to explain what happen ?
Attavit,
There is no document for this, I would recommend that you open a tac case, be sure to include tech support from the
C210 along with var/log/messages from Redhat OS.
Bill
did you get anywhere with this.. i would really appriciate if you can share what you did to get rid off those error msgs.
Hello Vijay,
If you are looking for information on SEL messages, please start a new thread and provide us specific log messages, CIMC version and server model.
The main issue with the original post was HBA connectivity and required TAC service request for investigation.
Padma
