UCS C22 M3 Cisco VIC 1225 no link
jkuehl
I have a C22 M3 with Vmware 5.5 running and a Cisco VIC 1225 card installed.  I have recently updated all the firmware to 2.0.3i on the box through CIMC.  I can see the Cisco VIC card installed and i have configured each port as a standard switch.
i have installed SFP-10G-SR fiber module in one of the ports.
Product name: UCS VIC 1225
Product ID: USCS-PCIE-CSC-02
Current Firmware: 4.0(1e)
I have my switch 4510R+E configured as the following:
interface TenGigabitEthernet2/1/1
description Cisco VM Fiber NIC
 switchport trunk native vlan 20
 switchport trunk allowed vlan 20
 switchport mode trunk
 spanning-tree portfast
is there any other configuration that i am missing on why i am not able to get a link between the server and switch?
Cool, I hope you also tried another port in the switch to be sure.
If the card was bad, please mark this thread as answered so that you can show future users you got this figured out; I hope I was of help somehow.
-Kenny
10 Replies 10
dangleminh
A direct connection to FI is required to manage a VIC card, see below:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c-series_integration/ucsm2-2/b_C-Series-Integration_UCSM2-2/b_C-Series-Integration_UCSM2-2_chapter_0110.html
The VIC 1225 is a PCIe card that can help you integrate your server directly to a Fabric Interconnect without the need of a FEX in between but you can also use that card if your server is in standalone mode.
Let me know if you have doubts.
-Kenny
Keny Perez
Level 8
Level 8
clear the counters for the interface on the switch and then post the output of show interface ten2/1/1 so that we can see if packets  are going through.
Are you tagging your traffic with vlan 20 on the vSwitch? if yes, that might be your issue cause you are telling your switch to expect that traffic untagged and keep it as such.
-Kenny
BM-CoreVSS-1#sh int te 2/1/1
TenGigabitEthernet2/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet Port, address is e4d3.f153.dea2 (bia e4d3.f153.dea2)
  Description: Cisco VM Fiber NIC
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-SR
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:00:23
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
This is what the current configuration on the CIMC and Vmware looks like.
The switch configuration is above.  I am going directly from the cisco VIC interface card and plugging directly into our Cisco 4510R+E switch.
If your interface is down/down your Layer 1 is having issues.... be sure you have known good cable and SFP, if you are using a twinax cable, replace it with another one and check the interface again... at this point there are no packets going through.
Let me know, but if the issue is solve with my suggestion, please mark it as "answered" so future users see you found the solution  for your question.
-Kenny
Currently Cisco TAC is sending me another Cisco VIC card to replace this one.
The fiber modules are from working systems and i have swapped out the fiber jumper with another one.
Will see if the card is defective.
-Kenny
Keny,
Card was defective, replacement card installed both ports came right up and traffic is flowing just fine.
Thanks for your troubleshooting tips, they did come in handy for future troubleshooting.
great, I am glad I helped :)
-Kenny
