1891
Enthusiast
UCS C220 CIMC KVM issues
Well its a java issue....no surprise there.
I am running java 7 U51 and cant get the kvm to launch. I get a unable to launch application. I have added the URL to the exception list in the Java settings, cleared browser cache and java temp files.
Running BIOS version 3.0.1a.0
Does anyone know the fix to this that works?
<jnlp codebase="https://10.1.200.104:443/*" spec="1.0+">
<information>
<title>Cisco Virtual KVM Console</title>
<vendor>Cisco Systems Inc.</vendor>
<icon href="https://10.1.200.104:443/images/logo.gif" kind="splash"/>
<shortcut online="true"/>
</information>
<application-desc main-class="com.avocent.nuova.kvm.Main">
<argument>title=10.1.200.104 - KVM Console</argument>
<argument>ip=10.1.200.104</argument>
<argument>vmprivilege=true</argument>
<argument>user=2044897763</argument>
<argument>passwd=1967513926</argument>
<argument>kmport=2068</argument>
<argument>vport=2068</argument>
<argument>apcp=1</argument>
<argument>power=1</argument>
<argument>vm=1</argument>
<argument>chat=1</argument>
<argument>statusbar=ip,un,fr,bw,kp,enc</argument>
<argument>tempunpw=1</argument>
<argument>version=2</argument>
<argument>aimpresent=1</argument>
<argument>export=1</argument>
<argument>custom=2</argument>
<argument>language=en</argument>
<argument>-Xmx512M</argument>
<argument>-Xms256M</argument>
<argument>dvr=2</argument>
</application-desc>
<security>
<all-permissions/>
</security>
<update check="always" policy="always"/>
<resources>
<j2se version="1.6.0_14+" href="http://java.sun.com/products/autodl/j2se" initial-heap-size="256M" max-heap-size="512M"/>
<jar href="https://10.1.200.104:443/software/avctNuova.jar" download="eager" main="true"/>
<property name="jnlp.packEnabled" value="true"/>
</resources>
<resources os="Windows" arch="x86">
<nativelib href="https://10.1.200.104:443/software/avctKVMIOWin32.jar" download="eager"/>
<nativelib href="https://10.1.200.104:443/software/avctVMWin32.jar" download="eager"/>
</resources>
<resources os="Windows" arch="amd64">
<nativelib href="https://10.1.200.104:443/software/avctKVMIOWin64.jar" download="eager"/>
<nativelib href="https://10.1.200.104:443/software/avctVMWin64.jar" download="eager"/>
</resources>
<resources os="Windows" arch="x86_64">
</resources>
<resources os="Linux" arch="x86">
<nativelib href="https://10.1.200.104:443/software/avctKVMIOLinux32.jar" download="eager"/>
<nativelib href="https://10.1.200.104:443/software/avctVMLinux32.jar" download="eager"/>
</resources>
<resources os="Linux" arch="i386">
</resources>
<resources os="Linux" arch="i586">
</resources>
<resources os="Linux" arch="i686">
</resources>
<resources os="Linux" arch="amd64">
<nativelib href="https://10.1.200.104:443/software/avctKVMIOLinux64.jar" download="eager"/>
<nativelib href="https://10.1.200.104:443/software/avctVMLinux64.jar" download="eager"/>
</resources>
<resources os="Linux" arch="x86_64">
</resources>
<resources os="Mac\ OS\ X" arch="x86_64">
<nativelib href="https://10.1.200.104:443/software/avctKVMIOMac64.jar" download="eager"/>
<nativelib href="https://10.1.200.104:443/software/avctVMMac64.jar" download="eager"/>
</resources>
</jnlp>
com.sun.deploy.net.FailedDownloadException: Unable to load resource: https://10.1.200.104:443/software/avctNuova.jar
at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source)
at com.sun.deploy.net.DownloadEngine.downloadResource(Unknown Source)
at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source)
at com.sun.javaws.LaunchDownload$DownloadTask.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
3 REPLIES 3
A few things to try:
-Go to Control Panel, click on Java icon, under General tab, Network Settings, click on Network Settings, choose Direct Connection, click OK. You should be able to launch the KVM now.
-Uncheck the proxy settings if using Google Chrome.
-Delete the following three folders:
  1. C:\Users\username\AppData\Local\Sun
  2. C:\Users\username\AppData\LocalLow\Sun
  3. C:\Users\username\AppData\Roaming\Oracle
-Check Java security settings
-Delete cache and temp files in the browser and Java
-Try Java 6u45 and uninstall other Java versions
-Try from a different PC
HTH,
Wes
I have
I have
$ java -version
java version "1.7.0_75"
Java(TM) SE Runtime Environment (build 1.7.0_75-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.75-b04, mixed mode)
And security settings should be as per attached
Highlighted
Beginner
Re: A few things to try:
This worked!
Running UCS C220-M3S
Deleted the AppData folders
Cleared browser cache
CIMC Firmware: 3.0.3(a)
Firefox: 68.0.1 (64-bit)
Java: 7 Update 21 (64-bit)
Set Security: Medium
Enabled all the TLS
Content for Community-Ad
August's Community Spotlight Awards
