Webcast- Catalyst 9000
87
Highlighted
Beginner
UCS C220 M5 - M.2 SWRAID Error
Dear guys,
I am having a trouble with Cisco UCS C220 M5. When I  boot to CIMC, there is an error as picture "M.2 SWRAID configuration is not detected". I tried "Load Manufacturing default" but it did not work.
6 REPLIES 6
Re: UCS C220 M5 - M.2 SWRAID Error
Do you have the M.2 controller installed? If so, I would reseat it and ensure the drive and controller are both secured on the motherboard.
Beginner
Yes, there is a M.2 controller with 2 SSDs on the motherboard. I tried reattached (or reseated) it but it still did not work.
Beginner
Additionally, when I tried installing RHEL, the server recognized 2 SSDs and no RAID. So I think the error come from the absence of Embedded Software Raid Controller. Do you have any ideas about this error?
Just to confirm, you have hit the <cntl> + M during post, for the megaraidSR config, and actually created a raid 1 virtual drive?
I've seen your exact same message for a new server out of the box that has no config for the embedded megaSR controller completed yet.
Kirk...
Beginner
Thanks for your reply.
Yes, I already created a raid 1 virtual drive last week. And I want to test the "mirroring" of raid 1 so I change the position of 2 SSDs in raid module :)). And after that, the error appear.
This is my first question in this forum so maybe you mistake me with someone :))
Check in BIOS if the SW RAID is enabled.
Step 1 Boot the server and press F2 when prompted to enter the BIOS Setup utility.
Step 2 Choose the Advanced tab, and then choose Mass Storage Controllers Configuration .
Step 3 Set Onboard SATA Controller to Enabled .
Step 4 Set SATA Mode to SW RAID .
Step 5 Press F10 to save your changes and exit the utility.
Once you confirm that SW RAID is enabled launch the LSI Software RAID Setup Utility
Press Ctrl-M during verbose boot, and re-configure RAID.
