05-29-2015 12:26 AM - edited 03-01-2019 12:12 PM
I have been encountering an issue while creating a virtual drive out of two HDDs and configuring RAID on them.
I hope, i can continue to create VD over CLI than GUI with no errors. But, is this something i need to worry about?
I couldn't find much in the troubleshooting guide on the error as well. Attached screenshot of error.
UCS C220
RAID Controller: LSI MegaRAID SAS 9266-8i
Firmware: 23.28.0-0010
Sami
Solved! Go to Solution.
05-29-2015 06:14 AM
Try to configure the VD from WebBIOS (reboot the server and press Ctrl+H when prompted during POST).
I dont have all the details bt you MIGHT be hitting this bug or a variant :
https://tools.cisco.com/bugsearch/bug/CSCuf80285/?reffering_site=dumpcr
HTH,
-Kenny
05-29-2015 06:14 AM
HTH,
-Kenny
05-29-2015 06:25 AM
Thanks Keny.
Yes, I will probably approach it via CLI. I am just wondering, as the server already on 2.0.1(b) and the bug was reportedly fixed on 1.5(2).
I will let you, if it works on the CLI
Thanks again.
06-24-2015 03:37 AM
Thanks Kenny, webBIOS worked for configuring new VD.
Sami
06-24-2015 06:20 AM
My pleasure!
-Kenny
