06-11-2018 01:00 PM - edited 03-01-2019 01:34 PM
Hey all,
Our server came shipped to us with 12 4TB drives and 2 4xxGB drives. In the CIMC I can see the 12 drives but the two smaller drives are no where to be found. The only place I see them is when I go to install ESXi. Under Storage > FlexFlash it shows hardware as mirrored but nothing else is populated.
06-11-2018 01:31 PM
I may have found my solution here.
06-11-2018 04:15 PM
That question has popped up quite a bit recently.
Glade the other post was able to assist your efforts.
Kirk...
06-12-2018 04:34 AM
I think I read in that thread that vmware doesn't like software raid, is that still accurate?
My plan for the server was to install esxi and then deploy a vm on it for veeam. But it might be easier to just put server on it.
06-12-2018 04:55 AM - edited 06-14-2018 06:19 AM
That is correct. You cannot use the MegaraidSR/C600 controller in software raid mode to install ESXi.
[EDIT/update] RHEL 7.3 and later (and related distros) pulled the megaSR driver out.
Currently, if you try to install RHEL 7.3 or later on a VD hosted by the embedded/c600 controller, it will not see the drive.
Kirk...
