Community Helping Community
790
Highlighted
Beginner
UCS Central Hierarchy Flow
Hi Guys,
I am starting to play with UCS central and understand the Domain Group Hierarchy flow.
I have configured one DG called test within UCS central.
I configured the DG root LDAP setting within operationals Management and expected to see this flow down to the UCS PE i registered within the test DG.
It looks like if i set the setting within the test DG directly the PE will pick up the setting.
So i guess my question show i expect to see the DG root setting being applied to the test registered UCS PE?
D
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: UCS Central Hierarchy Flow
HI Douglas,
You'll need to make sure that you have opted for Global Policy Control of User Management from the local domain first (see below).
Hope this helps,
  -Jeff
2 REPLIES 2
HI Douglas,
Hope this helps,
  -Jeff
Beginner
Hi Jeff,
I have all the local UCSM settings set as per the screenshot.
Douglas
Content for Community-Ad
FusionCharts will render here
