09-24-2017 11:53 PM - edited 03-01-2019 01:18 PM
Hello everbody,
is it possbile to configure QoS System Class Settings for a UCS Domain through Central? I know how to create a QoS System Class Policy for a domain Group within central but I cannot find out how to apply it. If I just create the Policy, the settings are not applied to the UCS Domains of the Domain Group. Also it's possbile to configure multiple QoS System Class Policies for a Domain Group, so my guess is there must be somewhere a setting where to activate a certain policy.
On the UCS Central Documentation I've only found the Point how to create the Policy.
Can somebody give me a hint how to apply the Policy?
Kind Regards
Lukasz
Solved! Go to Solution.
09-26-2017 04:50 AM
Here are steps to accomplish the QoS configuration. Let me know if there are issues.
https://supportforums.cisco.com/t5/data-center-documents/ucs-central-qos-configuration/ta-p/3189560
09-25-2017 05:06 AM
Can you confirm the UCSM version you are running? Per this document, you require 2.2.7:
09-25-2017 07:00 AM
Hello Wes,
I'm running UCSM 3.1.2 and UCS Central 2.0.1a.
Kind regards
Lukasz
09-25-2017 01:13 PM
Thanks Lukasz,
Reading the release notes here, it appears you may need 3.1.3 to support QoS with 2.0.
Cisco UCS Central Features
Supported Cisco UCS Central Versions
Supported Cisco UCS Manager Versions
2.1
2.2
3.0
3.1
Support for Second RAID Controller in the IO Expander on Cisco UCS S3260 Storage Server (UCS-C3K-M4RAID) | 2.0(1a) | No | No | No | 3.1(3) and later |
Support for Dual HBA Controller on Cisco UCS S3260 Storage Server (UCS-S3260-DHBA) | 2.0(1a) | No | No | No | 3.1(3) and later |
Support for Dual SIOC | 2.0(1a) | No | No | No | 3.1(3) and later |
Globalization of Service Profiles | 2.0(1a) | No | 2.2(8) and later | No | 3.1(1) and later |
BIOS Asset Tag | 2.0(1a) | No | No | No | 3.1(3) and later |
Hot patching/ Lightweight Upgrades | 2.0(1a) | No | No | No | 3.1(3) and later |
User-Defined Zone Profiles | 2.0(1a) | No | No | No | 3.1(3) and later |
Integrated Server Diagnostics | 2.0(1a) | No | No | No | 3.1(3) and later |
SED Security Policies, Smart SSD, and KMIP Support | 2.0(1a) | No | No | No | 3.1(3) and later |
Automatic Configuration of FI- Server Ports | 2.0(1a) | No | No | No | 3.1(3) and later |
Set KVM IP on physical servers | 2.0(1a) | No | No | No | 3.1(3) and later |
Fabric Evacuation in Firmware Auto Install | 2.0(1a) | No | No | No | 3.1(3) and later |
Direct Fabric Interconnect Evacuation | 2.0(1a) | No | 2.2(4) and later | No | 3.1(1) and later |
Launch HTML5 KVM Client | 2.0(1a) | No | No | No | 3.1(3) and later |
Multicast Policy | 2.0(1a) | No | No | No | 3.1(3) and later |
Power Sync Policy | 2.0(1a) | No | 2.2(8) | No | 3.1(2) and later |
Statistics Threshold Policy | 2.0(1a) | No | No | No | 3.1(3) and later |
Graphics Card Policy | 2.0(1a) | No | No | No | 3.1(3) and later |
QoS System Class | 2.0(1a) | No | No | No | 3.1(3) and later |
Hardware Change Discovery Policy | 2.0(1a) | No | No | No | 3.1(3) and later |
Port Auto-Discovery Policy | 2.0(1a) | No | No | No | 3.1(3) and later |
KMIP Certification Policy | 2.0(1a) | No | No | No | 3.1(3) and later |
Server Reboot Logs | 2.0(1a) | No | No | No | 3.1(3) and later |
Delete Decommissioned Rack Server, Chassis, FEX | 2.0(1a) | Yes | Yes | No | 3.1(1) and later |
However, I am currently deploying this in the lab using UCSM 3.1.3 and UCSC 2.0.1a and once complete, I will post some screen captures to help with configuration.
09-26-2017 12:04 AM
Thank you very much for your help.
09-26-2017 04:50 AM
09-26-2017 10:20 PM
Hello Wes,
thank you for the detailed description. I'll will try this by the end of the week. At the moment I don't have any UCS Domain running firmware 3.1.3 available.
Kind regards
Lukasz
