Field Notice 70545
1169
naimkharraz94
Beginner
UCS Director Problem
Hello Friends
When I want to open the UCS Director through the web I always found this phrase "The system is starting up. Please wait until the system is ready." I wait for hourses and nothing happen :(
1 ACCEPTED SOLUTION
nico13192
Beginner
can you please tell me the solution of this problem?
Thank you!
4 REPLIES 4
usmareedu
Beginner
I am having the same issue.. was it solved for you? If Yes, Please let me know how you  get away with this issue.
nico13192
Beginner
Thank you!
I just had to wait for 5 to 10 minutes and it is working. Restart of the services also was helpful sometimes.
I have installed UCSD in lab with very limited resources on VMware workstation.
I have now deployed UCSD 6.6 OVA 3 times on 2 different clusters in ESXi 6.5 and each time the VM fails to start. It appears to hang and has a small progress bar at the bottom of the console screen but no CPU activity. What is the solution?
Create
Recognize Your Peers
Content for Community-Ad
