UCS Emulator does not update
yuvaraj.mani
Hi All,
I am using UCS Emulator 1.4 version and beginer in UCS emulator, when I add Hardware in Inventory like Chassis, blade it is not refelecting inside the console, also if type any command like show or scope, it is taking time not responding... please let me know any clarification required, thanks for your response..
Yuvaraj.M
David Alpizar
Hi ,
I had experienced the same issues with the UCS emulator in that version.
I would recommend you to use the 2.0 version as it has been improved and some of these issues were corrected.
I hope this helps
- David
Hi David,
Thank you very much!! Its working in 2.0 UCSPE.....
regards,
Yuvaraj.M
