03-23-2020 07:27 PM - edited 03-23-2020 07:28 PM
Solved! Go to Solution.
03-24-2020 05:39 AM
It is usually firmware packages.
Go to equipment, equipment top object,,, then in right pane, firmware management,, then packages.
Delete any Infrastructure or B/C series bundles that you not using with your servers.
There can also be issues with left over tech supports, but usually it is lots of old previous firmware packages/bundles.
Kirk...
03-24-2020 05:39 AM
Kirk...
