123
Highlighted
Beginner
UCS Fabric Interconnect Capacity in Bootflash
Both of my fabric interconnects are complaining about too little disk space. But I'm not sure where to go to see what junk I can delete from there. In UCS Manager there's no place in FI to show the contents of bootflash. I went to the CLI and tried connect nxos thinking maybe I could show bootflash: there. But no go. And the main CLI had no show boot. ??
Affected object:sys/switch-A/stor-part-bootflash
Description:Disk usage for partition bootflash on fabric interconnect A exceeded 70%
1 ACCEPTED SOLUTION
Highlighted
Re: UCS Fabric Interconnect Capacity in Bootflash
It is usually firmware packages.
Go to equipment, equipment top object,,, then in right pane, firmware management,, then packages.
Delete any Infrastructure or B/C series bundles that you not using with your servers.
There can also be issues with left over tech supports, but usually it is lots of old previous firmware packages/bundles.
Kirk...
1 REPLY 1
Highlighted
Kirk...
Content for Community-Ad
Cisco COVID-19 Survey
