02-19-2018 10:56 AM - edited 03-01-2019 01:26 PM
I need to unconfigure two FC ports on UCS 6324. I have read some documentation that states "You cannot unconfigure FC Ports". Do I have to do a full config erase for this to change back to ethernet ports? Any help of guidance would be much appreciated.
Solved! Go to Solution.
02-19-2018 11:28 AM
Problem solved.
Selected 'Configure Unified Ports' when a Fabric Interconnect is selected. I was expecting the option to be on the FC port. Why would I check where I configured the FC port in the first place? SIlly me!
Thank you, Wes!
02-19-2018 10:58 AM
What are you trying to do exactly?
Yes, if you want to change FC port to Eth or FCoE, it will require a reboot of the 6234, as the ports will need to be re-programmed accordingly.
02-19-2018 11:02 AM
moving away from Fiber Channel to iSCSI. I need to reclaim the current FC ports for direct attached storage. There are no options to revert back to Ethernet in UCS Manager. I tried via the cli and get the error message "Error: Update failed: [FC Port B/1/1 cannot be unconfigured]"
02-19-2018 11:28 AM
Problem solved.
Thank you, Wes!
