Ben,
Just be sure you follow the guide in the sense of what portion of the UCS needs to be activated first.
There is a process of update which does not have an specific order for the different components, but you need to be careful with the activate process, that one has a very specific order so just be sure yuo follow it 100%.
In regards to issues, refer to the release notes not only for the version you will upgrade to but also the nexy one after that one, there might be known issues fixed until the next patch release, however in this case you are planning on upgrading to the latest version available
*** The procedure is made to have minimal disruption and make the upgrade successful, however it is ALWAYS recommended to perform this under a maintenance window. Waiting for the worse but hoping for the best. Good luck! ***
-Rate all helpful answers.
-Kenny
Message was edited by: Keny Perez
