robbeck
UCS Communities Login ID: robbeck
Twitter handle (optional): TechBeck03
Have you read the Official Rules of the Contest and do you accept the terms and conditions     Yes  [X ]    No  [   ]
Are you a Cisco employee        Yes  [ X]    No  [   ]
Does the script run on an emulator -        Yes [ X ]    No  [   ]
          If yes which version? 2.2(x) for full compatibility
v2.5 Edit:  Added a new check for the Firmware Auto Sync Policy (credit to Marcello Turano)
v2.4 Edit:  Added support for Ucs PowerTool 2.x and fixed timestamp
v2.3 Edit:  Fixed FC uplink SAN performance data and added single psu support
.DESCRIPTION
                Script for polling multiple UCS Domains and creating an html report
  of the domain inventory, configuration, and overall health
  .PREREQUISITES
  Powershell version 3.0 or higher
  Connection to the internet
  UCS PowerTool version 1.1.1 or higher
  VIDEO TUTORIAL
Video Link : 15145
  .SCRIPT USAGE NOTES
  Before generating the report select option 1) from the root menu
  and connect to target UCS Domains.  Cache domain credentials after
  connecting to speed up future script executions.
  You must have an active internet connection to view the report as it
  streams some javascript and css files to build report
  Use the UsedCache, RunReport, Silent, and Email switch options to automate
  script execution (especially if scheduling script as a task)
  Ex: .\UCS_Health_Check_v2.5.ps1 -UseCached -RunReport -Silent -Email user@domain.com
.REPORT USAGE NOTES
The generated html report supports multiple domains worth of data.  Use the Domain
dropdown at the top of the page to switch between UCS Domains.  Some of the table
entries can be clicked for a more detailed view.  There are help icons with tooltips to
help explain the capabilities of each table.
Include your script here:
Shayne niu
Community Member
So great script , impressive!
tcdissns
Community Member
I've installed Powershell 4, .NET framework 4.5 and UCS PowerTools 1.3.
When I run "C:\MyScripts\UCS_Health_Check_v2.1.ps1) I get the following error: "This script requires UCS PowerTool Modules". Any ideas?
What are the steps to cache your credentials to the ucs_cache.ucs file?
95huskers
Awesome script.  Very impressive output formatting.
Great work!
dwoodward
Has anyone used this with AD/LDAP integration setup?  How would I specify a local login vs. an AD login when connecting via this script?
robbeck
Yes this will work with an AD user account.  How you format the username depends on your default authentication method.  If your default is local (which it is by default) then you'd format the username as:
ucs-<Domain Name>\userName
where <Domain Name> is the case sensitive name you gave the AD domain in UCS Manager.
If your default authentication is set to LDAP then you simply use the username and password without the ucs-<Domain Name>
Please let me know if you have any issues.
KaraciaJM
Community Member
Might be a long shot, but what are the chances you could add the Contract End Date for each serial number either on the inventory page or a separate page?
We seem to have the hardest time keeping an accurate list of all an inventory, and this script has corrected that. Now just looking for a way to quickly see when stuff is going off contract so we can proactively renew.
Thanks!
robbeck
Great idea John but unfortunately there aren't any external tools i know of that allow for polling support contract details.  I could create a reports page that allows you to download the serial numbers into a csv but you'd have to work through a partner or cisco rep to get the contract details.
If we ever release an external portal with an API to expose this contract data then we could add this to the health check report.
SeanHay01
Community Member
For some reason both the online and offline versions of this tool are generating blank reports.  The utility is able to connect to the domain and it takes about 4-5 min. to finish but when I open up the html file it doesn't have any of the data populated.
robbeck
Could be a browser issue as it uses javascript behind the scenes.  Could you send me your html file please.
robbeck@cisco.com
SeanHay01
Community Member
Sent you the generated report.  It's odd because the sample one attached to this article displays without a problem.
tlundgard
Community Member
Exellent tool, but I'm having some minor issues running UCSM 2.2(3d) and CiscoUcs-PowerTool-1.1.2.0.exe with PowerShell 3.0. All columns in the html output are displayed perfectly, except for the SAN part / tab of the html output. Cannot see any of the SAN Uplink Ports in any browser, even if I know the SAN Uplinks are configured in UCSM. Any ideas what could be the issue? Thanks for any help.
maneesh25
Thanks robbeck for this wonderful scripts.provide a whole loads of info and scheduling it as a task is running perfectly.
Just have a small issues seems related to thomas where the report doesnot show SAN uplink Ports or storage ports..I am running UCS 2.2(3d)...Though it shows the details for UCS domain running on 2.1(3a).
Could you please advise..
tlundgard
Community Member
I know Brandon Beck will fix this in version 2.3. He replied to my e-mail on the 18th of June. We just have to be patient :
---- Brandon Beck (robbeck) wrote ----
Unfortunately this is a known issue because I only had fcoe attached storage and the logic is different for native FC.  I was waiting for someone to complain before I took the time to fix it
I’ll work on a version 2.3 with the fix.
Thanks!
Brandon Beck |  Technical Solutions Architect
kuldeep.jhala
Community Member
Great script , very impressive!
tjoffs
Community Member
Has a fix for this been found?  I have dug through the code and am baffled by this.  I have tried multiple machines, etc and cannot get this report to actually write the HTML with actual data.
