UCS MGMT0 and Nexus 7k
ManiacMurphy
So I am currently bringing up a new UCS cluster and having connectivity issues after the initial configuration. These are 6120s cabled to a Nexus 7k. All signs on the Fabric Interconnects look good and the group managing the Nexus 7k say it is configured properly and of course we have triple checked physical connectivity. In our other deployments we usually have the MGMT ports connecting to a separate catalyst 4948 so in the absense of anything else my mind is jumping on this configuration change. I haven't found anything that says don't cable your MGMT to a Nexus but I am wondering if any one can think of a technical issue that would prevent the MGMT network to work while cabled to a Nexus rather than a traditional switch?
5 Replies 5
Robert Burns
Going to ask the obvious, but have you configured the Mgmt0 1G Interface as an Access port on the N7K?  There's no trunking on the Mgmt0 interface of the 6100.
Does the port come up on the N7K?
Robert
Yes the port shows as connected on the N7k side and I am taking it at the trust of the group that configured it that it is configured as an access port. And just to get it out of the way, MTU, duplex and speed have all been confirmed on the link on the Nexus side as well.
I appreciate all comments even those considered obvious so thanks Robert.
Don't "trust" anyone
Can you get the switch interface config from the N7K where UCS Mgmt0 connects?  Please post it here.
An easy test, is get your N7K guys to setup an SVI on the N7K for the VLAN used for UCS management (rather than rely on pinging the default gateway).  If you can't ping this SVI address from the UCS CLI (local-management), then your problem is isolated to either one of these devices.  Could just be the management VLAN for UCS hasn't been created or trunked between your N7K and upstream network somewhere...
From the UCS CLI can you also plaste the output of:
show cluster state
Robert
Got the port config and it is setup in access mode. Also confirmed the VLAN is created on the switch. I am still investigating the possibility of it not being configured for the upstream connections
Eth2/16       119     eth  access up      none                       1000(D) --
Ethernet2/16 is up
  Hardware: 10/100/1000 Ethernet, address: 30e4.db0c.a53b (bia 30e4.db0c.a53b)
  Description: UCS_mgmt
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 1000 Mb/s
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 2d12h
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 528 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 520 bps, 0 pps
  RX
    20 unicast packets  0 multicast packets  17 broadcast packets
    37 input packets  2748 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    24 unicast packets  120157 multicast packets  38 broadcast packets
    120219 output packets  16447099 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
  5 interface resets
Thanks Kevin.
I'd do the SVI ping test next.  That will tell you if youi're problem is on UCS or northbound of your N7Ks.
Robert
