UCS Mini B200 M4
Is Cisco UCS B200 M4 supported on UCS mini solution ?
When I check UCS B200 M4 data sheet below it says " The UCS B200 M4 Blade Server mounts in a Cisco UCS 5100 Series blade
server chassis or UCS Mini blade server chassis."
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/b200m4-specsheet.pdf
But I can not configure UCSB200 M4 on CCW when I choose UCS mini chassis.
Bikash
2 Accepted Solutions
Just got the information that it will be supported with 3.0(2) release, expected Q2CY15.
Hi Walter,
Now I can add UCSB-B420-M4 to UCS mini chassis on CCW. But this is on hold till 29th Feb 2015.
Bikash
7 Replies 7
Walter Dey
Hi Bikash
You are right; technically B200-M4 works, however, the UCS mini web site
http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-mini/solution-overview-c22-732813.html
doesn't mention it yet as supported. This is why CCW doesn't show it. Someone from Cisco Product Management can help here.
Hi Walter,
Thank you very much. I am more confused when I see below deployment scenario page 49-51 of below document.
http://www.cisco.com/c/dam/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/spec_sheet_c17-644224.pdf
Bikash
Hi Bikash
I believe this is an issue with the ordering tool CCW; I would just go ahead, and order B200-M4 as spare; technically it is working and supported.
Cheers Walter.
Hi Walter,
Have you ever tested B200-M4 in UCS Mini Chassis (Cisco UCS 6324 Fabric Interconnect ) ? If yes, then I go ahead and propose to my customers.
Bikash
Hi Bikash
No I didn't ! the available Firmware 3.0d doesn't support it yet
It's not yet in the Support matrix
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
nor release notes
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/ucs_3_0_rn.html
Release Notes for Cisco UCS Manager, Release 3.0, for Cisco UCS Mini
First Published: July 23, 2014
Last Updated: December 4, 2014
Cheers Walter
Hi Walter,
Bikash
