Which method i have to use to replace a faulty chassis in a UCS Mini deployment after to receive a new chassis for RMA??
It needs only to change the blades and fabric interconnects from the faulty chassis to the new chassis, or i have to take another task in consideration??
Assuming you are only replacing the 5108 chassis, and not replacing the 6324 FI/IOMs, then your configs should be retained.
As always, make sure you make backups of your logical, system, and full state, for worse cast scenarios.
Kirk...
If you are dropping the blades and FI/IOM modules into a new chassis, then you may have a new chassis # assigned due to the changed serial # when it discovers.
I believe you should be able to decomission the chassis, and edit the chassis # in while it is listed in the decomissioned tab be fore re-ack'ing.
Kirk...
