06-23-2017 04:51 AM - edited 03-01-2019 01:13 PM
Hi all,
I'm trying to find the correct SNMP OID to monitor the interface queues of my 6248UP's
It is easy enough to check the dropped packets in the queue via cli :
KOR-J11-FI4-A(nxos)# sh queuing interface eth1/29
Pkts discarded on ingress : 128771804
But i need to get this value via SNMP and i just cant find the correct OID
According to this page there is 1 MIB that handles QoS : CISCO-UNIFIED-COMPUTING-EPQOS-MIB
But i just can find anything that links to the queue drop counter ...
Any idea's ?
Grtz
Thijs
Solved! Go to Solution.
06-26-2017 05:45 AM
I had the same response on my N5548 until I updated to 7.0(5)N1(1)
I am now getting a response and counter output at 1.3.6.1.4.1.9.9.166
I would expect to see this ported to the UCS at somepoint since it is now available in later N5K code.
Kirk...
06-23-2017 02:36 PM
Greetings.
I skipped through the UCSM related MIBs, and don't think that info is exposed to SNMP.
I think that used to the be case for N7ks, but more recent code seems to have something similar to what you are looking for. See http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.166 and http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/system_management/7x/b_5500_System_Mgmt_Config_7x/class_based___quality_of_service_mib.html although this does not help your UCSM request :)
I can file an enhancement request, but frankly I just haven't seen any customer requests for it at UCSM level, which is usually what drives getting the new features/enhancements implemented.
Kirk...
06-26-2017 02:34 AM
Thanks for the feedback Kirk, i appreciate it !
I have gone tough the info you linked to and there are a couple of interesting objects like these :
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropPkt64.285212681.285212682 = Counter64: 0 CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropPkt64.285212681.285212686 = Counter64: 0 CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropByte64.285212681.285212682 = Counter64: 0 CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropByte64.285212681.285212686 = Counter64: 0 CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropBitRate.285212681.285212682 = Gauge32: 0 bits per second CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropBitRate.285212681.285212686 = Gauge32: 0 bits per second
However, none of these work :
If i do a walk on 1.3.6.1.4.1.9.9.166 i get 'object not found'
The 6248UP is based on a Nexus5k, but maybe there is a difference in SNMP capabilities ?
Unfortunately I currently dont have a N5k running so i cant verify
EDIT : just fired up a 5548UP (version 5.2(1)N1(2a)) and tried a walk on 1.3.6.1.4.1.9.9.166 > same result 'object not found'
It looks like this is a general N5k thing, not limited to UCSm
EDIT2 : did the same test on a nexus9k N9K-C9504 (NXOS: version 7.0(3)I4(5)) and here it works
Any ideas ?
Grtz
Thijs
06-26-2017 05:45 AM
Kirk...
06-26-2017 05:45 AM
Thanks for the update Kirk
I guess i'll just have to wait then
Do you know if there is a way that i can track this ?
Grtz
Thijs
