06-10-2019 10:13 AM
I'm trying to download UCS firmware using the Get-UcsSoftwareImage and it doesn't work. Simple example of commands:
$ccoCred = Get-Credential
$ucsImages = Get-UcsSoftwareImageList -Credential $ccoCred
$ucsImages | where { $_.ImageName -like "ucs-k9-bundle*4.0.4*A.bin" } | Get-UcsSoftwareImage -Path "C:\Users\xxxxxxx\Downloads\ucs" -verbose
I receive an error message, "Get-UcsSoftwareImage : ucs-k9-bundle-infra.4.0.4b.A.bin : EULA_FORM_AR::Eula form have not been accepted or rejected to continue download."
I found some references to adding a "-EulaAccepted" parameter to the Get-UcsSoftwareImage. That fails with an "Get-UcsSoftwareImage : A parameter cannot be found that matches parameter name 'EulaAccepted'." error.
I reviewed the UCS Manager Firmware Upgrade with UCS PowerTool from scripts index/examples and I don't see anything appropriate.
I'm using UCS PowerTools Suite 2.5.1.6 and I tried the next previous release.
Is this a bug with the Get-UcsSoftwareImage cmdlet?
Solved! Go to Solution.
06-21-2019 05:08 PM
Testing in my lab I was getting the same error. After some hours I got an email to accept an EULA here: https://software.cisco.com/download/eula
After doing so and running the PowerTool commands again it started my download. Just leave out the "-EulaAccepted" parameter.
06-21-2019 05:08 PM
06-24-2019 08:22 AM - edited 06-24-2019 08:23 AM
I received the same EULA emails -- their subject was "Action Required to Download Cisco Software for your device(s)". I'm pretty sure I went to the URL and accepted the EULA then retried the Get-UcsSoftwareImage command without luck.
I just accepted the EULA via that URL then ran the PowerShell commands to connect, get S/W list, and download one file -- it worked. Maybe I'm mis-remembering or I needed to establish a fresh session to CCO via PowerShell after accepting the EULA or something else was going on. Regardless, I appears to work now. I will perform some more testing to verify it continues to work.
Thanks for looking into it and responding.
06-27-2019 06:32 AM
Tested again today and the Get-UcsSoftwareImage is working without issue.
It may be worth adding info about needing to and how to accept the EULA to Get-UcsSoftwareImage's help page.
Thanks again.
