11-16-2021 01:02 AM
Hi! does cisco have a documentation that UCS can store its data in almost unlimited time during a power outage?
11-16-2021 04:11 AM
Greetings.
Can you be a little more specific and add some context to your question?
Are you talking about the UCSM configs from the fabric interconnects?
Those run off of SSD/flash drives, where the working and startup configs are also saved.
You're not going to loose configs from those, even if they are powered off for a number of months.
Kirk...
11-16-2021 06:57 PM
I think it is the data of their application stored in the storage. ex: c220 servers with windows OS experience power outage for long time.. the enduser need a documentation that specify the data stored on the disks will not be corrupted.
11-17-2021 06:46 AM
From OS perspective, power outage, is always susceptible to file system corruption. That's what UPSs are for;)
If you are asking about the raid controller cache memory backed by battery, then
"This server supports installation of one supercap unit. The unit mounts to a bracket in-line with the fan modules.
The optional SCPM provides approximately three years of backup for the disk write-back cache DRAM in the case of a sudden power loss by offloading the cache to the NAND flash."
Let me know if that's what you are after.
Kirk...
