06-14-2012 07:30 AM - edited 03-01-2019 10:27 AM
Is it possible to power off the UCS if the temperature sensor reading exceeds a certain value?
Can I power off the UCS remotely?
06-14-2012 07:54 AM
Steve,
No. The thresholds are not configurable. This ensures we can set the thresholds according to manufacturing specs to ensure the HW is always protected.
regards,
Robert
06-14-2012 07:57 AM
Thanks Robert. Will the UCS power off when this threshold is voilated?
06-14-2012 08:04 AM
Hello Steve,
UCSM will not auto shutdown the blades and it is left to CPUs to control the action based on inbuilt thermal characteristics.
You can remotely power down blades using IPMI commands.
https://supportforums.cisco.com/message/3625575#3625575
Padma
06-14-2012 08:12 AM
Thanks. I will do some reasearch on the IPMI commands.
