06-14-2014 01:30 AM - edited 03-01-2019 11:42 AM
We are doing UAT testing for our newly installed 6248 FI's with following details and we are observing some unusual behavior
FI-A - 172.10.15.51 (Primary)
FI-B - 172.10.15.52 (Secondary)
Cluster IP - 172.10.15.50
If we are shutting down the FI-A (Primary), the Cluster IP is not getting fail over to FI-B and FI-B is not be promoted as Primary
Is there any issue related to 2.2(1b)?
06-14-2014 03:47 AM
Did you check the cluster status, before the test: CLI show cluster status ?
Can you clarify what you mean with shutting down FI-A ? power off ?
ssh to FI-B, after shutting FI-A, and do CLI show cluster status ?
06-14-2014 08:57 AM
Below is the output before power off FI-A
lavender-A(local-mgmt)# show cluster extended-state
Cluster Id: 0x7bce8766ecdc11e3-0xa1b4002a6ac23b41
Start time: Sat Jun 14 21:05:55 2014
Last election time: Sat Jun 14 21:17:57 2014
A: UP, PRIMARY
B: UP, SUBORDINATE
A: memb state UP, lead state PRIMARY, mgmt services state: UP
B: memb state UP, lead state SUBORDINATE, mgmt services state: UP
heartbeat state PRIMARY_OK
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, UP
HA READY
Detailed state of the device selected for HA storage:
Chassis 1, serial: FOX1812GNZZ, state: active
Chassis 2, serial: FOX1813GFT7, state: active
Chassis 3, serial: FOX1814G5DR, state: active
Below is the output after shutting down the FI-A
lavender-B(local-mgmt)# show cluster extended-state
Start time: Wed Jun 11 19:09:13 2014
Last election time: Sat Jun 14 13:45:18 2014
B: UP, PRIMARY, (Management services: SWITCHOVER IN PROGRESS)
A: DOWN, INAPPLICABLE
B: memb state UP, lead state PRIMARY, mgmt services state: INVALID
A: memb state DOWN, lead state INAPPLICABLE, mgmt services state: DOWN
heartbeat state SECONDARY_FAILED
eth1, DOWN
eth2, DOWN
HA NOT READY
Management services: switchover in progress on local Fabric Interconnect
Its really strange that when I do the manual cluster lead change, its taking good amount of time to switch the VIP from FI-A to FI-B wise a versa
Amit Vyas
06-14-2014 12:00 PM
I assume, initially you can of course ping FI-A and B, and VIP ?
Now as can be seen, FI-A is down; and FI-B is primary ? can you now ping FI-B and VIP ?
06-16-2014 12:07 AM
I can only ping FI-B and unable to ping VIP until FI-A come up
06-16-2014 07:33 AM
Must be a bug !
btw. did you set this ??
admin->managementInterfaces->managementInterfaceMonitoringPolicy
Admin status -> enable
MII status
06-16-2014 08:59 AM
After an upgrade to UCSM 2.2.1b we see the following symptoms:
- No UCSM GUI access.
- Virtual IP is not reachable.
- Virtual IP cannot be accessed either by GUI or CLI/SSH.
- Individual FI can be accessed via SSH but not via http.
<B>Conditions:</B>
- Issue occurred after an upgrade to version 2.2.1b.
- The issue can happen in the following two conditions:
1. default keyring is deleted and the system is upgraded to 2.2.1<x>
2. When default keyring is deleted on a system running 2.2.1<x> and the system is rebooted.
Workaround:
Workaround:
- Make the key and certificate links used by apache httpd to point to any valid key/certificate (by deleting and re-creating the links). This requires loading debug plugin.
The situation can be avoided by:
1. not deleting the default keyring (or recreating it if deleted) before upgrading to 2.2.1<x>.
2. Not deleting the default keyring even after upgrading to 2.2.1<x>
<B>Further Problem Description:</B>
Issue is caused because of deadlock.
06-17-2014 03:21 AM
I am also assume the same that it might be a bug
Yes, Admin status is enabled and Monitoring Mechanism is MII Status
But above setting also didn't help, when I restarted the primary FI, I lost the ping VIP and FI-A and VIP response came after FI-A came up
06-17-2014 04:57 AM
Hi Amit
I hope you have seen the bug id below !
Walter.
06-19-2014 06:00 AM
I am not hitting this bug, because these devices are shipped with 2.2.(1b)
Not sure what will be the issue ?
06-19-2014 06:10 AM
Understood, but it could also happen, if
06-19-2014 06:37 AM
No, haven't delete key ring but have rebooted FI's multiple times
06-19-2014 10:59 PM
I would open a TAC case, and/or upgrade the infrastructure with autoinstall to the latest, resp. long lived Cisco recommended release (2.2.1d)
06-23-2014 05:42 AM
I have raised the SR and TAC engineer is working on it
Mean while I wanted to know / understand following two things
