07-13-2016 12:08 AM - edited 03-01-2019 12:48 PM
Hi Guys , hope you are all fine .
I'm getting some error when trying to login to UCS Manager [see screenshot below]
I'm familiar with this error when the primary FI is down , but here , both FIs are up [pingable] .
Can someone please assist ? we can't access UCSM , and we really need it now ...
Thanks in advance !
07-13-2016 03:03 AM
Hi Ron
UCSM is a application which runs on the primary FI ! if you connect the browser to the VIP, you are always directed to the primary. You cannot connect to the subordinate.
You can SSH (eg. putty) to both primary and subordinate.
07-13-2016 04:21 AM
Hi Walter , thanks for your reply .
I know that [i'm working with it 4 years :) ]
that's exactly the issue , that although it should take me to the primary node , like always , it gives me this error ....
07-13-2016 04:27 AM
Sorry Ron for this misunderstanding !
You are connecting to the VIP, and get this error message ? correct ?
Which UCS version ?
07-13-2016 05:00 AM
VIP ? you mean the "floating" address ? if so , then Yes .
and that's what i'm getting .
version 2.2(5a)
07-13-2016 05:07 AM
Hi Ron.
Putty/SSH into your vip
#connect local-mgmt a|b
#show cluster extended
#show pmon state
See if the cluster output show either FI having issues, or if the pmon state shows any of the listed services as having been restarted.
If they do, you will likely want to open a TAC case to have this reviewed.
Kirk...
07-13-2016 05:12 AM
07-13-2016 05:18 AM
The DME has seen at least one restart.
What is the output for the B side?
Kirk...
07-13-2016 05:21 AM
07-13-2016 06:06 AM
Ron,
You can attempt to access UCSM using the Virtual (Floating) IP address or the IP address of the Primary Fabric Interconnect. Are you able to access UCSM from the primary FI's IP address?
-Wes
07-13-2016 06:28 AM
a is now primary; I would try to make b the primary, and check again.
connect local
cluster lead b
07-14-2016 12:28 AM
Hi Walter , I'll try it later , and will tell you what happened .
BTW - maybe restart FI-B will help ?
07-14-2016 01:15 AM
Hi Walter ,
I did "cluster lead b" , and not i'm able to login to UCSM !
what you think caused it ?
is it OK to stay like that ?... I prefer that A will be the primary ...
BTW - take a look what i'm seeing in UCSM [See the attached pictures]
thanks in advance !
07-14-2016 02:07 AM
Hi Ron
I hope you always tried to connect to the VIP IP address and/or the IP address of the master FI ?
In principle, it is totally irrelevant, which FI is master, which one is subordinate !
Regarding F999616 error, see http://www.kozeniauskas.com/itblog/2013/01/12/ucs-f999616-fsmfailed-communication-service-configurationfsmsamdmecommsvcepupdatesvcep/
This tells me that UCS cannot get IP address for NTP server. So this could be that FQDN for NTP server is incorrect, DNS is not configured in or DNS server is not reachable.
btw. did you try http as well as https ? and different browsers ?
Walter.
07-14-2016 02:16 AM
