UCSM failed login , not available on secondary node
Ron Baduach
Hi Guys , hope you are all fine .
I'm getting some error when trying to login to UCS Manager [see screenshot below]
I'm familiar with this error when the primary FI is down , but here , both FIs are up [pingable] .
Can someone please assist ? we can't access UCSM , and we really need it now ...
Thanks in advance !
32 Replies 32
Hi Ron
Something must be really sick; this cluster lead command takes only a few seconds !
Q. was this configuration ever running properly ?
Can you please post the IP address of FI-A, FI-B and VIP ?
Are they in the same IP subnet / vlan as the KVM addresses ?
Regarding NTP/DNS
- did you configure DNS ? any typo ?
- did you configure NTP ? any typo ? I see that your date / time is totally wrong !
- assuming IP connectivity is ok, I would try NTP IP address instead of DNS name.
Walter.
Hi Wlater ,
1. From what i know the config ran properly .
2. FI-A - 10.56.27.19
FI-B - 10.56.27.20
FI-VIP - 10.56.20.10
the same subnet/vlan as the KVM .
3. Me personally didn't configured NTP/DNS , but the guy that worked on it , that now fired , maybe did it .
Can you dell me how to check ? and I'll configure NTP & DNS with IP
4. BTW - is there any command that can stop the switchover ?... [see screenshot]
[I tried to get back FI-A to be primary (by rebooting FI-B , and firce FI-A to be primary ...)]
Walter , thanks for your help
Hi Ron
Looks strange to me
FI-A - 10.56.27.19
FI-B - 10.56.27.20
FI-VIP - 10.56.20.10  !!!!!!!!!
why not eg.
FI-A - 10.56.27.19
FI-B - 10.56.27.20
FI-VIP - 10.56.27.21
what is the network mask ?
sorry sorry sorry
TYPO :)
VIP IP - 10.56.27.10
all of it /24
BTW - now , when A is primary again , FI-A falls once in a few minutes ..
You mean FI-A crashes ?
Please check if you you see dump files !
1. yes, FI-A ,it crashed twice , but i don't think that rebooted , because in 20-30 seconds it back to life , so probably was some network connectivity down .
Now , after configure the NTP as needed [i saw that what was configured is not in use anymore...] , it's not crashed ..
2.don't know what is dump files and how to check if they are existing...
3. So now it not crashes , but i'm still with the issue that i mentioned in the screenshot ...
A middle conclusion -
In the beggining , FI-A was primary but i could not access UCSM
Now, FI-A again is the primary [after moved it to FI-B] , and now UCSM is accessible , but , i got 2 things :
a. the one in screen shot "FI-A"
b. the one in screenshot "EthPorts"
again , thanks for the help , and for keep assist with it !
In the attachments, you see how to configure DNS, NTP and check for core (dump) files.
Thanks ! Like i said in the previous comment , i succeeded with it !
1. about core [dumps] files , see the attachment .
2.Please take a look on my previous comment if you missed it
thanks again !
It seems that your time is not up to date ! NTP doesn't seem to work ! In show cluster ... I see December 2015 !
Q. is this a productive environment or lab ?
It seems that FI-B has a problem, therefore cluster lead b doesn't work.
One could disconnect the heartbeat cables, then erase configuration on FI-B, reconnect the cable, and join the cluster (entering the FI-B IP address) and then synch the configuration from FI-A.
Walter.
Hi Walter ,
The 2015 is the "start time" , but take a look at "last election time" , it's now , 2016 .
also , when running "show clock" on both FIs , the time is fine [although FI-A is in 40 minutes late , although they both have the same NTP server...]
It's between lab to production , we can get it down if needed [but , the ESXis will be down too ???]
Hi Ron
yes, you are of course right !
Something with NTP is still wrong ! or did you manually configure date/time on each FI ? is F999616 still there ?
Did you check, that ESXi switch has connectivity to both fabrics ?
If yes, bringing down one fabric should not disrupt ESXi.
Walter.
PS. the core files are old ! Is this a rather old hardware ? FI 61xx ?
Yay!
Something with NTP is still wrong ! is F999616 still there ?
Nope , not there.
I'll check , thanks for the info !
Hi Walter , we'll probably will go on your suggestion .
"One could disconnect the heartbeat cables, then erase configuration on FI-B, reconnect the cable, and join the cluster (entering the FI-B IP address) and then synch the configuration from FI-A."
Just two things :
1. what the exact command to erase the configuration from FI-B ?
2. How do I sync the config from FI-A to FI-B ? it should happen automatically after join FI-B to the domain ? (entering FI-B IP Address ?)
Hi Ron
Enter “connect local-mgmt”
Enter “erase configuration”
During boot:
connect the heart beat cable => FI-B will recognize a peer and asks if it should join to create cluster => yes
the synch is completely automatic No action required ! just be patient ! depending on the size of the configuration it may take time 10 + minutes
thanks a lot ! will let you know once done !
