07-13-2016 12:08 AM - edited 03-01-2019 12:48 PM
Hi Guys , hope you are all fine .
I'm getting some error when trying to login to UCS Manager [see screenshot below]
I'm familiar with this error when the primary FI is down , but here , both FIs are up [pingable] .
Can someone please assist ? we can't access UCSM , and we really need it now ...
Thanks in advance !
07-24-2016 11:45 PM
Hi Walter and all ,
the issue solved by restarting FI-A
it backed to normal state , all is up now , the ntp is sync in both FIs .
all is fine now !
thanks all for your help ! thanks a lot Walter , i learned lot from this "journey"
07-14-2016 12:27 AM
Hi Wesley ,
I tried also to access UCSM via FI-A IP Address , and got the same error .
07-13-2016 05:09 AM
Please provide output for the following commands
connect local-management
show cluster extended-state
If HA is ready, please check the pmon processes to make sure all are running:
show pmon state
