Highlighted
UCSM Firmware clean-up.
Good Morning,
    Lately we upgraded our UCSM farm to FW 3.2(2b). This work super great of course.  we notice a few new errors that puzzled us for a while "Disk usage for partition WHBP35464 bootflash exceeded 70% ", So we figured out that was caused by all the Firmwares we implanted during the last 3 years and that are still lingering in the boot partition, we can see them in Equipment/Firmware Management/Packages.
So my questions are:
what can we get rid of safely?
old Catalogue files?
once implemented do we need to keep the Infrastructure Bundle?
B/C series if they are not used do we need them?
also is there a UCS central function or cleanup task for this...
Stephane.
Stephane Beausoleil
virtualisation architect
CGI
3 ACCEPTED SOLUTIONS
Highlighted
Start by getting rid of old A (infrastructure) bundles. You are safe to delete any A bundles that you are not using. You may keep a stable older version in case for whatever reason to decide to roll back. Otherwise, no need to have multiple A bundles.
You can get rid of C-bundles if you do not have C-series.
Otherwise, I would start by getting rid of the oldest packages first, provided they are no longer in use. If you accidentally delete a package that is in use, just be sure to re-upload it immediately. This will not cause an immediate reboot, however, you will get a lot of faults for missing images.
Good Luck.
Highlighted
Correct, the latest catalog will contain all images from previous catalogs. These typically don't take up too much space, but definitely are safe to delete.
Highlighted
Thanks that is very useful information's.
I will proceed with my clean-up activities.
TX.
Stephane Beausoleil
CGI
4 REPLIES 4
Highlighted
Good Luck.
Highlighted
What about catalogue? Can I keep only the last one?
Stephane Beausoleil
CGI
Highlighted
Highlighted
TX.
Stephane Beausoleil
CGI
Content for Community-Ad
