Highlighted
Beginner
UCSM infra setup upgrade from 2.2(3b) to 3.2(1b)
I would like to upgrade the UCSM infra setup from 2.2(3b) to 3.2(1b).
So please can someone help/guide  me that below steps are correct to achieve my upgrade task.
->First Upgrade UCSM from 2.2(3b) to 3.1(3c) and then upgrade blade firmware to 3.1.3c.
->Then upgrade from 3.1(3c) to 3.2(1b) and then upgarde blade firmware  to 3.2.1d
Additional Info : The UCSM Infrastructure running with ESXi host with 5.5 and also please find attached screen shot to know details of my setup with firmware versions
However I have one question that if I upgrade UCSM from .2(3b) to 3.1(3c) and then 3.2(1b),does my current Adapter(VIC 1240)  supports the target version since I m not finding this adapter version under  Adapter minimum software versions for adapter table, so I’m in confusion state .(see Table 14 in release notes )
Release Notes for Cisco UCS Manager, Release 3.1 https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/CiscoUCSManager-RN-3-1.html
Adapters
Adapters
Minimum Software Version
UCS 6200 Series FI
UCS 6332, 6332-16UP
UCS 6332, 6332-16UP
Recommended Software Version
UCS 6200 Series FI
UCS 6332, 6332-16UP FI
UCS-IOM-2204
UCS-IOM-2208
UCS-IOM-2204
UCS-IOM-2208
UCS-IOM-2304
UCS-IOM-2204
UCS-IOM-2208
UCS-IOM-2304
UCSC-PCIE-C40Q-03
UCSC-MLOM-C40Q-03
  1. 2.2(7b)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCS-VIC-M82-8P
UCSB-MLOM-40G-01
UCSB-MLOM-PT-01
  1. 2.2(1b)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCSB-MLOM-40G-03
UCSB-VIC-M83-8P
UCSC-MLOM-CSC-02
  1. 2.2(3a)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCSC-PCIE-CSC-02
  1. 2.2(1b)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCSC-F-FIO-1000MP
UCSC-F-FIO-1300MP
UCSC-F-FIO-2600MP
UCSC-F-FIO-5200MP
  1. 2.2(3a)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCSB-FIO-1600MS
UCSB-FIO-1300MS
  1. 2.2(3a)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCSC-INVADER-3108
UCSC-NYTRO-200GB
  1. 2.2(3a)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCSC-MLOM-C10T-02
UCSC-PCIE-C10T-02
UCSC-F-FIO-785M
UCSC-F-FIO-365M
UCSC-F-FIO-1205M
UCSC-F-FIO-3000M
UCSC-F-FIO1000PS
UCSC-F-FIO1300PS
UCSC-F-FIO2600PS
UCSC-F-FIO5200PS
UCSC-F-FIO-6400SS
UCSC-F-FIO-3200SS
  1. 2.2(4b)
  2. 3.1(1e)
  3. 3.1(1e)
  4. 3.1(3c)
UCS-MEZ-QLG-03
UCSB-MEZ-ELX-03
N20-AQ0102
N20-AE0102
  1. 2.2(3a)
  1. 3.1(3c)
UCS-PCIE-E14102B
  1. 2.2(7b)
  1. 3.1(3c)
UCSC-PCIE-IQ10GF
UCSC-PCIE-ID10GF
UCSC-PCIE-ID40GF
  1. 3.1(2b)
  2. 3.1(3c)
UCSC-F-I80010
UCSC-F-I12003
UCSC-F-I160010
UCSC-F-I20003
UCS-PCI25-40010
UCS-PCI25-8003
UCS-PCI25-80010
UCS-PCI25-16003
UCSC-F-H19001
UCSC-F-H38001
UCS-SDHPCIE800GB
UCS-SDHPCIE16TB
UCS-PCI25-38001
  1. 3.1(2b)
  2. 3.1(3c)
UCSC-PCIE-QD32GF
N2XX-AQPCI05
UCSC-PCIE-Q2672
UCSC-PCIE-BD32GF
UCSC-PCIE-BS32GF
UCSC-PCIE-E16002
N2XX-AEPCI05
UCSC-PCIE-ID10GC
  1. 3.1(3a)
  2. 3.1(3c)
Table 14 Minimum Software Versions for Adapters
Looks forward your help.
1 ACCEPTED SOLUTION
Highlighted
Hi Shankrappa,
you will not loose both FI at the same time.  if you use the automated method only one FI will get the update at a time.
you will get kick out of management for a while but that's all. if all your Blades are properly configures and have all there multi-path enable (network and Storage) your covered.  one path will drop during the update but that's all.
if your running esx just make sure all your hba and nic are dual or that you enable failover in the UCSM (there is that possibility to but I prefer to let the esx handle its failover) and in window if you have any installed on blades you have to be sure that vnic and hba have there dual path configured properly (most of the wintel world folk know about hba multi pathing but less about the Ethernet dual nic bounding)
if you cover this your A ok!
We do our upgrade from ucs Central automatically just by pushing a update policy of the UCS firmware and all of our 200 Blades just live trough it without issue.
so if you check all the base stuff it will work out.
Steph.
Stephane Beausoleil
virtualisation architect
CGI
7 REPLIES 7
Highlighted
the latest version is 3.1.3c and it does support the vic1240.
you should also make sure you use the Cisco oem esx iso to upgrade your host to keep the esx platform compliant.
as for 3.2 I am not there yet.
Stephane Beausoleil
CGI
Highlighted
Thanks Stephane for your information.
However i have one more query that, does both FI's will lost connection after upgrade of UCSM to 3.1.3c and before starts of upgrading of FI"s (i would be preferring manual way of upgrading each components) since as per below release notes, minimum Software version for FI would be 2.5(1a),but current FI's running with 2.2(3b
Current  FI's are 6248 UP with  below versions
kernel version : 5.2(3) N2(2.23b)
System version : 5.2(3) N2(2.23b)
Package Version : 2.2(3b)
Fabric Interconnect
Fabric Interconnect
UCS 6248UP
2.5(1a)
3.1(1l)
UCS 6296UP
2.5(1a)
3.1(1l)
Highlighted
Hi Shankrappa,
Steph.
Stephane Beausoleil
CGI
Highlighted
Thanks for your information stephane
But actually my concern is when I do upgrade manually ,first I will upgrade UCSM to 3.1 and then will go for  upgrading FI’s,So before actually upgrade of FI’s, does UCSM 3.1 supports existing FI ( As per release notes of 3.1, minimum FI for FI is 2.5(1a)),but my existing /current FI’s have 2.2(3b) version
Highlighted
Hi Shankrappa,
There is just one step you misunderstood.  Upgrading the UCSM to 3.1 Will upgrade the First FI to.  the Manager/gui is part  of the FI's, so when you do you upgrade it will upgrade the FI's at the same time this is not a separate process.
And frankly you should not do the process manually.  the automated install is working properly.
Stephane Beausoleil
CGI
Highlighted
Thanks for your response stephane.
Highlighted
Beginner
Can  any one please help/direct me on upgrade path for UCSM
Content for Community-Ad
