03-07-2018 06:41 AM - edited 03-01-2019 01:27 PM
So...
I need to upgrade two 5108 Chassis / B200 M2 and I have some doubts.
1st- Which version should I use? I took a look at the https://ucshcltool.cloudapps.cisco.com/public/ but I am not sure abou it.
2nd- How to performe the upgrade, I mean ... I know that there are a lot of guides eg https://www.cisco.com/c/en/us/support/servers-unified-computing/ucs-manager/products-installation-guides-list.html, but I need some more summarized.
Thanks in advance!!
03-12-2018 09:49 PM
Apart from hardware compatibility, you need to evaluate OS and SAN devices ( switches, arrays ) compatibility
I would suggest you to verify your environment against latest patch release of UCSM 2.2.8 series
You can perform the infra upgrade ( i.e UCSM FI / IOM NXOS ) via Auto-Install method.
For blades, you can perform the upgrade host firmware policy and reboot one at a time or in batches.
After the upgrade, make sure you upgrade the drivers within the OS.
Padma
03-13-2018 02:06 PM
Thanks Padmanabhan!!
I guess for the currently hw, version 2.2(8i) is supported.
UCS 5108
FABRIC INTERCONECT – 6248UP
B200 M2 – 2.0(5C)
IO MODULE-2208XP – 2.0(5C)
ADAPTERS- M81KR
CPU- A01-X0102 X5670 2.93GHZ
I'll check the OS version and if there are some SAN devices.
Where could I found the OS upgrade drives? You told that I must upgrade the OS first!!
03-13-2018 02:18 PM
You would need to use the interop matrix to confirm your OS is supported, but yes, that combination should be fine.
The drivers can be downloaded from Cisco for the firmware bundle
05-18-2018 12:26 PM
Thank you Wesley!! sure about delay!!!
