10-08-2018 12:22 AM
We are planning to upgrade UCS firmware from 3.1.3c to latest stable 4.0.1b (starred). We checked the compatibility for Windows 2016 & ESXi 6.7 and found it's compatible. The drivers that we run with the servers are 3.2.1b. Our concern is shall we do the upgrade safely and also upgrade the drivers from 3.2.1b to the latest. Last time we found 3.2.3c was the stable & recommended version of the firmware, but now that version is not at all listed with Cisco download.
Thanks in advance
10-08-2018 06:35 AM
Dear,
Using following link check out for Compatibility as per Server Model/Type, OS running etc. for CIMC Firmware Versions and for drivers or adapters.
Cheer's
10-08-2018 06:35 AM
Following the link: https://ucshcltool.cloudapps.cisco.com/public/
10-08-2018 06:41 AM
