03-06-2014 11:41 AM - edited 03-01-2019 11:34 AM
Hi All,
I would like to know if anybody has recently upgrade from the above mentioned version , I would like to know if you have found amy documents detailing the steps to carried out . Is it a smooth transition ? your input in invaluable .
Sincerely,
Saleem Roumaldaro.
03-06-2014 11:56 AM
Hi Saleem ,
Take a look at the upgrade guide in order to have the limitations and recommendations for the upgrade in the system:
Hope this helps!
David
03-06-2014 12:02 PM
Hi David,
I will take a look at it, does autoinstall works well if i am upgrading from 2.1(1A) to 2.1(2a) ?
Saleem
03-06-2014 12:07 PM
Saleem ,
Yes, the auto install option will be available for the 2.1 version.
Hope this answer your question.
-David
