09-11-2012 02:43 AM - edited 03-01-2019 10:36 AM
I try upgrading my Nexus 5548 with the release 5.1(3)N2(1b)
But I see that the image is'y not compatibible with the module 1 !!!
I followed the Upgrade and Downgrade Guide.
Help me.
********************************************** CLI output *************
sw-tdb-nx5548-1# show install all status
This is the log of last installation.
Verifying image bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin for boot variable "kickstart".
SUCCESS
Verifying image bootflash:/n5000-uk9.5.1.3.N2.1b.bin for boot variable "system".
SUCCESS
Verifying image type.
SUCCESS
Extracting "system" version from image bootflash:/n5000-uk9.5.1.3.N2.1b.bin.
SUCCESS
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin.
SUCCESS
Extracting "bios" version from image bootflash:/n5000-uk9.5.1.3.N2.1b.bin.
SUCCESS
Extracting "fexth" version from image bootflash:/n5000-uk9.5.1.3.N2.1b.bin.
SUCCESS
Recommended action::
"Module 1 might not be supported in the new image,
it should be powered off before proceeding with install".
Performing module support checks.
SUCCESS
Notifying services about system upgrade.
SUCCESS
Compatibility check is done:
Module bootable Impact Install-type Reason
1 no n/a n/a Incompatible image
101 yes non-disruptive rolling
Images will be upgraded according to following table:
Module Image Running-Version New-Version Upg-Required
1 system 5.1(3)N2(1) 5.1(3)N2(1b) no
1 kickstart 5.1(3)N2(1) 5.1(3)N2(1) no
1 bios v3.5.0(02/03/2011) v3.5.0(02/03/2011) no
1 SFP-uC v1.0.0.0 v1.0.0.0 no
101 fexth 5.1(3)N2(1) 5.1(3)N2(1b) yes
1 power-seq v1.0 v1.0 no
3 power-seq v2.0 v2.0 no
1 uC v1.2.0.1 v1.2.0.1 no
sw-tdb-nx5548-1#
sw-tdb-nx5548-1#
sw-tdb-nx5548-1#
09-11-2012 06:21 AM
I do a mistake on my command line !!
Bad bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin.
Now, it's Ok.
Cdlt,
12-17-2012 03:47 PM
Hi, I have the same issue, how did you fix this?
12-17-2012 04:46 PM
I was using an bad command, the right one is:
install all kickstart bootflash:n5000-uk9-kickstart.5.1.3.N2.1b.bin system bootflash:n5000-uk9.5.1.3.N2.1b.bin
Now the Nexus is upgraded.
