Upgrading Nexus 5548 UP, Release 5.1(3)N2(1b)
a.auvinet
I try upgrading my Nexus 5548 with the release  5.1(3)N2(1b)
But I see that the image is'y not compatibible with the module 1 !!!
I followed the Upgrade and Downgrade Guide.
Help me.
********************************************** CLI  output *************
sw-tdb-nx5548-1# show install all status
This is the log of last installation.
Verifying image bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin for boot variable "kickstart".
SUCCESS
Verifying image bootflash:/n5000-uk9.5.1.3.N2.1b.bin for boot variable "system".
SUCCESS
Verifying image type.
SUCCESS
Extracting "system" version from image bootflash:/n5000-uk9.5.1.3.N2.1b.bin.
SUCCESS
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin.
SUCCESS
Extracting "bios" version from image bootflash:/n5000-uk9.5.1.3.N2.1b.bin.
SUCCESS
Extracting "fexth" version from image bootflash:/n5000-uk9.5.1.3.N2.1b.bin.
SUCCESS
Recommended action::
"Module 1 might not be supported in the new image,
it should be powered off before proceeding with install".
Performing module support checks.
SUCCESS
Notifying services about system upgrade.
SUCCESS
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1        no             n/a           n/a  Incompatible image
   101       yes  non-disruptive       rolling
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version  Upg-Required
     1      system             5.1(3)N2(1)            5.1(3)N2(1b)            no
     1   kickstart             5.1(3)N2(1)             5.1(3)N2(1)            no
     1        bios      v3.5.0(02/03/2011)      v3.5.0(02/03/2011)            no
     1      SFP-uC                v1.0.0.0                v1.0.0.0            no
   101       fexth             5.1(3)N2(1)            5.1(3)N2(1b)           yes
     1   power-seq                    v1.0                    v1.0            no
     3   power-seq                    v2.0                    v2.0            no
     1          uC                v1.2.0.1                v1.2.0.1            no
sw-tdb-nx5548-1#
sw-tdb-nx5548-1#
sw-tdb-nx5548-1#
a.auvinet
I do a mistake on my command line !!
Bad  bootflash:/n5000-uk9-kickstart.5.1.3.N2.1.bin.
Now, it's Ok.
Cdlt,
Hi, I have the same issue, how did you fix this?
I was using an bad command, the right one is:
install all kickstart bootflash:n5000-uk9-kickstart.5.1.3.N2.1b.bin system bootflash:n5000-uk9.5.1.3.N2.1b.bin
Now the Nexus is upgraded.
