When the hypervisor partition is not sync between the two SD cards, you will see an error message on the CIMC under the Storage tab after you select Cisco Flexflash controller. Note that this feature became available after firmware version 1.5, so if your servers are running code prior to that the raid configuration between the SD cards won't be available.
Please let me know if this help and rate any helpful post.
