11-16-2017 12:09 PM - edited 03-01-2019 01:21 PM
In a scenario in which I have I have associated a vHBA to a VSAN with multiple interfaces and also associated with a ping group, in case of failure
will the repining be done to another interface of the same VSAN or due to the ping group configuration havéra repining?
Note: I use Brocabe in the SAN so I do not use port channel.
Thanks to anyone who can help.
Solved! Go to Solution.
11-16-2017 12:24 PM
Right, you are pretty much telling the vHBA "You are only to use this uplink, if it fails, remain down until it comes back online"
If you want to dynamically re-pin to another uplink, just let the UCS select the pinning for the uplinks. It will evenly distribute the load over all uplinks.
11-16-2017 12:19 PM
If you use a pin group for your vHBA, if the port fails, the vHBA will not failover to another uplink.
11-16-2017 12:22 PM
In other words, vHBA ignores the VSAN configuration for multiple interfaces, correct?
11-16-2017 12:24 PM
