Highlighted
Beginner
Virtual Ethernet Interface identification in UCS
I would appreciate pointers or information that will help me identify UCS-5108 blade server and physical ethernet interfaces based upon a Veth#### value I get via CLI or SNMP from a UCS FI 6248. For example, using the command 'show mac address-table dynamic' on a 6248 CLI, I get the following information:
* 903      0025.b500.000e    dynamic   0          F    F  Veth1892
* 903      0025.b500.003f    dynamic   0          F    F  Veth1676
* 903      0025.b500.004f    dynamic   0          F    F  Veth1668
* 903      0025.b500.005e    dynamic   0          F    F  Veth1884
* 903      0025.b500.006e    dynamic   0          F    F  Veth1876
* 903      0025.b500.009f    dynamic   10         F    F  Veth1660
* 903      0025.b500.00af    dynamic   0          F    F  Veth1868
* 200      0050.5686.5d0d    dynamic   0          F    F  Veth1876
* 200      0050.5686.5d0e    dynamic   0          F    F  Veth1852
* 200      0050.5686.5d10    dynamic   0          F    F  Veth1876
* 200      0050.5686.5d13    dynamic   0          F    F  Veth1852
* 200      0050.5686.5d17    dynamic   0          F    F  Veth1916
* 200      0050.5686.5d1c    dynamic   0          F    F  Veth1892
How do I know what 5108 chassis, FEX uplink, physical ethernet port each of those Veth### ports are?
TIA,
Angel
1 ACCEPTED SOLUTION
Highlighted
Hello Angel,
The following SAM CLI command provides complete path info for server NIC / vHBA
              show service-profile circuit server X/Y
There are other commands which does not completely trace the path.
connect nxos
show pinning border-interfaces
show pinning server-interfaces
Padma
2 REPLIES 2
Highlighted
Hello Angel,
connect nxos
Padma
Highlighted
Padma,
Thank you for the reply. It helps. I also contacted a Cisco TAC engineer, and got a reply with valuable information. It turns out that the Cisco UCS FI 6248 is quite similar to a Cisco Nexus 5500. I can use similar CLI commands and verify Virtual and physical interfaces. The following comamnds are quite useful to get what I was looking for:
- connect nxos
- sh run int veth####
- sh int veth####
Or
Under the SAM CLI:
- sh service-profile circuit detail
- sh service-profile circuit server x/y
Cheers,
Angel
Content for Community-Ad
