11-06-2012 11:07 AM - edited 03-01-2019 10:42 AM
I would appreciate pointers or information that will help me identify UCS-5108 blade server and physical ethernet interfaces based upon a Veth#### value I get via CLI or SNMP from a UCS FI 6248. For example, using the command 'show mac address-table dynamic' on a 6248 CLI, I get the following information:
* 903 0025.b500.000e dynamic 0 F F Veth1892
* 903 0025.b500.003f dynamic 0 F F Veth1676
* 903 0025.b500.004f dynamic 0 F F Veth1668
* 903 0025.b500.005e dynamic 0 F F Veth1884
* 903 0025.b500.006e dynamic 0 F F Veth1876
* 903 0025.b500.009f dynamic 10 F F Veth1660
* 903 0025.b500.00af dynamic 0 F F Veth1868
* 200 0050.5686.5d0d dynamic 0 F F Veth1876
* 200 0050.5686.5d0e dynamic 0 F F Veth1852
* 200 0050.5686.5d10 dynamic 0 F F Veth1876
* 200 0050.5686.5d13 dynamic 0 F F Veth1852
* 200 0050.5686.5d17 dynamic 0 F F Veth1916
* 200 0050.5686.5d1c dynamic 0 F F Veth1892
How do I know what 5108 chassis, FEX uplink, physical ethernet port each of those Veth### ports are?
TIA,
Angel
Solved! Go to Solution.
11-06-2012 06:50 PM
Hello Angel,
The following SAM CLI command provides complete path info for server NIC / vHBA
show service-profile circuit server X/Y
There are other commands which does not completely trace the path.
connect nxos
show pinning border-interfaces
show pinning server-interfaces
Padma
11-06-2012 06:50 PM
Hello Angel,
connect nxos
Padma
11-07-2012 07:38 AM
Padma,
Thank you for the reply. It helps. I also contacted a Cisco TAC engineer, and got a reply with valuable information. It turns out that the Cisco UCS FI 6248 is quite similar to a Cisco Nexus 5500. I can use similar CLI commands and verify Virtual and physical interfaces. The following comamnds are quite useful to get what I was looking for:
- connect nxos
- sh run int veth####
- sh int veth####
Or
Under the SAM CLI:
- sh service-profile circuit detail
- sh service-profile circuit server x/y
Cheers,
Angel
