185
Highlighted
Beginner
Vlans for Port-Channel in UCSM
Greetings,
     I have configured a port-channel with two network uplink Ethernet in Fabric Interconnect A. This configuration is replicated on the secondary Fabric Interconnect B. At this point, the uplink Ethernet haven't been physically connected to the other device.
The problem I faced is that I didn't want any vlans to be configured on the port-channel. However, it showed that some vlans are already configured on the port-channel in the CLI. Result is as below:
interface port-channel2
description U: Uplink
switchport mode trunk
switchport trunk allowed vlan 1,899-904,2000-3000,3333
pinning border
speed 10000
Any advice will help.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Vlans for Port-Channel in UCSM
Greetings.
That is the default behavior on the UCSM.   All global or local vlans per side, are allowed on all uplinks, unless you configure otherwise.
Its sounds like you may be wanting to configure what is termed a disjoint layer 2 config where not all uplinks carry the same vlans.
Please see https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/unified-computing/white_paper_c11-692008.html where it shows how to 'prune' the various vlans off of links in vlan manager.
Kirk...
1 REPLY 1
Greetings.
Kirk...
Content for Community-Ad
August's Community Spotlight Awards
