09-11-2012 12:53 PM - edited 03-01-2019 10:37 AM
Any reasons why when using the Configure VMware Integration wizard the port profiles/DVS was not created in vCenter?
The plugin is ok and I was following the doc from Cisco:
Page 33, Applying Port Profiles and Configuration to vCenter Server.
09-11-2012 07:37 PM
Do you receive any error message on UCS or vcenter ?
Padma
09-13-2012 06:21 AM
I am thinking it might be a firewall issue as the Interconnects and VC pass a firewall..... I can't find any documents that state what exact ports need to be open, I am thinking 443 and 80......
# tail-mgmt-log svc_sam_extvmmAG
INFO][0xb5a48bb0][Sep 12 10:08:06.171][sam_extvmmAG:SC_Read_v] SC_Read_vsh_data() read: ERROR: [VMWARE-VIM] Operation could not be completed due to connection failure.Timeout. connect failed in tcp_connect()
[INFO][0xb5a48bb0][Sep 12 10:08:06.172][agdriver:CmdExecFinish] VSH-WATCHDOG: Command 'connect' took 160 seconds to complete
[INFO][0xb5a48bb0][Sep 12 10:08:06.172][sam_extvmmAG:SC_Execut] Error Executing command (ret_val=0xfffffe0c, errno=25, parse_error=0x0, callback_called=1)
09-13-2012 09:14 AM
UCSM connects to vcenter on port 80 and currently does not have feature change the port number.
Apart from firewall rules, is vcenter listening on port 80 ?
Padma
09-13-2012 07:02 PM
Ya, port 80 was blocked on the firewall... It works like a charm now....
