09-21-2012 09:14 AM - edited 03-01-2019 10:38 AM
I believe a new vem vib is required for use with esxi 5.1 - would this be within the new 2.0(4a) release? I can't find any reference within the release notes..
Solved! Go to Solution.
09-25-2012 08:53 AM
Hello Nael,
VM-FEX in all ESXi 5 releases use the same driver (v132-4.2.1.1.4.1.0-3.0.4). I will have the Interop Matrix updated.
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
http://www.cisco.com/en/US/partner/products/ps10477/prod_technical_reference_list.html
Matthew
09-25-2012 08:53 AM
Hello Nael,
Matthew
09-26-2012 12:20 AM
Thanks...
