06-13-2014 07:56 AM - edited 03-01-2019 11:42 AM
Hi, does the C220 support VMQ? We are seeing performance issues on a Windows 2012 Hyper-V host where VMQ is default enabled and suspect that lack of VMQ support might be the reason for it.
06-15-2014 12:44 AM
Have you checked your BIOS settings according to
http://www.cisco.com/c/en/us/products/collateral/servers-unified-computing/ucs-b-series-blade-servers/whitepaper_c11-727827.html
and regarding VMQ support see release notes
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/release/notes/ucs_2_2_rn.html
06-15-2014 10:54 AM
Hi wdey, I should add that they are running standalone and not managed by UCS so the release notes you suggested are not applicable here. I have checked bios and can´t find anything about VMQ there.
06-16-2014 05:36 AM
Hi Andreas
I understand; if you read the doc about c-series server, mananged by UCSM, you see the following p 287ff
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/cli/config/guide/2-2/b_UCSM_CLI_Configuration_Guide_2_2.pdf
- If you want to configure the VMQ vNIC on a service profile for a server, at least one adapter in the server must support VMQ. Make sure the servers have at least one the following adapters installed:• UCSC-PCIE-CSC-02 (this is the VIC-1225)
- When a VMQ vNIC is configured on service profile, make sure you have the following settings:
• Select SRIOV in the BIOS policy.
• Select Windows in the Adapter policy.
- Create a VMQ connection policy:
UCS-A# scope org
UCS-A /org # create vmq-conn-policy policy name
UCS-A /org/vmq-conn-policy* # set queue-count queue count (number)
UCS-A /org/vmq-conn-policy* # set interrupt-count queue count (number)
UCS-A /org/vmq-conn-policy* # commit-buffer
I don't have a server at this moment to test; I assume (hope), that CIMC of a standalone server should allow you to do the same commands.
Walter.
06-16-2014 07:59 AM
Hi, in this case they are using the P81E adapter and i believe that it doesn´t support VMQ, it´s discontinued and not listed in the document you referred to. I will look into this further and let you know what i find out.
