02-23-2015 05:09 AM - edited 03-01-2019 12:02 PM
Chassis - M5108
FIs - 6248
IOMs - 2204
Uplink > Brocade ICX6450(Layer2) > Cisco 5525x(Gateway sub interfaces)
Hi, I'm setting up a new, and my first UCS, single chassis with four blades to hosts a Hyper-V. The setup is quite straight forward, everything appears to be correct, the service profiles generate, I can make use of the KVM to connect and install 2012R2, the vNICs are generated and i've loaded the USC eNIC drivers, verified the vNICs by MAC address to that in UCSM to ensure the IP being set is on the correct vLAN.
But for all my trying, I cannot uncover where I've misconfigured the stack. When I give the vNICs an IP address in their vLAN they cannot arp the default gateway, windows reports them as ipv4 Connectivity: No network access.
I've have 7vNICs to each blade. As all are exhibiting the same problem i've been concentrating on vLAN 175, which is to be my blade host OS management interface.
Its as if the vLANS are not being forwarded across the uplink, over the FIs to the vNIC. I cant find any tooling such as ping to make use of to half the problem.
My vLAN to vNIC mapping is 1 to 1 per blade, I've tried setting the vLAN to native on the vNIC, no change.
Can anybody help with some debug tips for the uplink?
Im struggling to halve the problem to understand if its broken in the brocade trunk, as the KVM untagged ports do not prove this, of in the fabric interconnects.
The only peculiarity seems to be 'show int brief' from the nxos as these do not show veth 823/824 in vLAN 175.
Though the GUI: Servers>Service Profiles>HV_HOST2>vNICS>vNIC Host_OS>vLANSs>Host_OS does list vLAN 175 checked as its ID.
I cant set the vLANs in nxos :/
I've installed wireshark on the windows host, i can see ARP requests for the gateway leaving with I ping from command line, there is no response received.
I apologise for the lengthy post - trying to give as much detail i can think off -- really appreciate any help you may be able to offer.
Danny
Some of my config which may help :
Concentrating on Server 2, vNIC HOST_OS, network 10.10.172.0/24 .1 is gateway, .102 the host NIC.
Eth1/3 on the FI are my uplinks to the Brocade.
I can see from the GUI: Equipment > Server2 > NICs than NIC-1 is the correct HW address as reported in windows.
It has VIF 823 and 824, and vNIC HOST_OS.
NXOS shows vLAN 175 Mapped to veth824 on Fabric B ::
175 VLAN0175 active Eth1/3, Veth795, Veth809
Veth823, Veth865
NXOS shows vLAN 175 Mapped to veth823 on Fabric A::
Veth823, Veth865
Both veth's show as up on the respective FIs::
qsucs1-B(nxos)# show interface vethernet 823
Vethernet823 is up
Bound Interface is port-channel1281
Port description is server 1/2, VNIC HOST_OS
Hardware is Virtual, address is 002a.6afb.3080
Port mode is trunk
Speed is auto-speed
Duplex mode is auto
qsucs1-A(nxos)# show interface vethernet 824
Vethernet824 is up
Bound Interface is port-channel1280
Hardware is Virtual, address is 002a.6afb.3620
Port mode is trunk
Speed is auto-speed
Duplex mode is auto
300 seconds input rate 0 bits/sec, 0 packets/sec
300 seconds output rate 0 bits/sec, 0 packets/sec
qsucs1-B(nxos)# show interface brief
Ethernet VLAN Type Mode Status Reason Speed Port
Interface Ch #
Eth1/1 1 eth fabric up none 10G(D) --
Eth1/2 1 eth fabric up none 10G(D) --
Eth1/3 1 eth trunk up none 10G(D) --
Vethernet VLAN Type Mode Status Reason Speed
Veth795 175 virt trunk down nonParticipating auto
Veth798 1 virt trunk down nonParticipating auto
Veth799 1 virt trunk down nonParticipating auto
Veth802 1 virt trunk down nonParticipating auto
Veth804 1 virt trunk down nonParticipating auto
Veth805 1 virt trunk down nonParticipating auto
Veth807 1 virt trunk down nonParticipating auto
Veth809 175 virt trunk down nonParticipating auto
Veth812 1 virt trunk down nonParticipating auto
Veth813 1 virt trunk down nonParticipating auto
Veth816 1 virt trunk down nonParticipating auto
Veth818 1 virt trunk down nonParticipating auto
Veth819 1 virt trunk down nonParticipating auto
Veth821 1 virt trunk down nonParticipating auto
Veth823 1 virt trunk up none auto
Veth826 1 virt trunk up none auto
Veth827 1 virt trunk up none auto
Veth830 1 virt trunk up none auto
Veth832 1 virt trunk up none auto
Veth833 1 virt trunk up none auto
Veth835 1 virt trunk up none auto
Veth865 175 virt trunk down nonParticipating auto
Veth868 1 virt trunk down nonParticipating auto
Veth869 1 virt trunk down nonParticipating auto
Veth872 1 virt trunk down nonParticipating auto
Veth874 1 virt trunk down nonParticipating auto
Veth875 1 virt trunk down nonParticipating auto
Veth877 1 virt trunk down nonParticipating auto
Interface Ch #
My Brocade, uplink switch config - this provides also vlan168 which is my KVM Lan.
1/1/1 1GB is a link to the Cisco 5525x with sub interfaces or each vLAN.
1/1/3 and 1/1/4 are my 1GB links to the Management Interfaces on the Fabric Interconnects/KVM (working)
1/2/1 and 1/2/3 are two 10GB links to the Eth3 on each of the Fabric Interconnects
Running config:
vlan 168 name HW_MGT by port
tagged ethe 1/1/1
untagged ethe 1/1/3 to 1/1/4
management-vlan
default-gateway 10.10.168.1 1
vlan 172 name VHPRDMGT by port
tagged ethe 1/1/1 ethe 1/2/1 ethe 1/2/3
vlan 173 name VHDEVSVC by port
vlan 174 name VHPRDSVC by port
vlan 175 name HOST_OS by port
Show trunk:: Trunk two uplink ports to the FIs 1/2/1 and 1/2/3
Configured trunks:
Trunk ID: 65
Hw Trunk ID: 1
Ports_Configured: 2
Primary Port Monitored: Jointly
Ports PortName Port_Status Monitor Rx_Mirr Tx_Mirr Monitor_Dir
1/2/1 none enable off N/A N/A N/A
1/2/3 none enable off N/A N/A N/A
Operational trunks:
Trunk ID: 65
Hw Trunk ID: 1
Duplex: Full
Speed: 10G
Tag: Yes
Priority: level0
Active Ports: 2
Ports Link_Status port_state
1/2/1 active Forward
1/2/3 active Forward
Show vLAN:
PORT-VLAN 175, Name HOST_OS, Priority level0, Spanning tree On
Untagged Ports: None
Tagged Ports: (U1/M1) 1
Tagged Ports: (U1/M2) 1 3
Uplink Ports: None
DualMode Ports: None
Mac-Vlan Ports: None
Monitoring: Disabled
02-23-2015 01:14 PM
Hi Danny
Can you please post a diagram of your setup !
- are your UCS FI in Ethernet end host mode
- you are not using Fibrechannel ?
- Normally all vlans are trunked from FI North bound
- How does your service profile look like ? to which fabric are the vnics connected ? A or B ? did you select hardware failover
- is each vlan available on fabric A and B ?
- W2012 sees 7 access interfaces, one vlan per interface ?
- do have North bound vlan L2 connectivity ?
Walter.
02-23-2015 01:38 PM
Hi Walter, thank you the help
Answers inline:
Ill draw one, i have a design document with each step detailed ive executed - i can email this in the interim if useful?
Yes
No - at this stage im deploying once 4 2012r2 DC builds to host a hyper visor, VMs to be hosted on CSV over local disks in the blades.
I have 6 vlans with gateways on a cisco firewall. There is an intermediary switch between the firewall and the Fabric Interconnects. At the switch my hardware vlan(168) is untagged and presented over cat6 to the management interfaces of the fabric interconnects. The remaining 5 vlans remain tagged and are trunked over two 10Gbit links to eth3 on each Fabric. There are two more vlans in the fabric, 1 for CSV and 1 for Live Migration.
There are interleaved across both, but all vlans are set to failover
They are all added in the community space, this should then be available to each fabric.
Yes one vlan per vNIC presented to the hosts.
HOST_OS, CSV, LVMGR are type adaptor. There are then four more for VMs which are Adaptor and VM type.
I have been struggling to test this - vlan 168 untagged at the switch is for sure working as i can connect to the KVM, mounth virtual media, install the OS.
Mapping the MAC address to a NIC in Windows and putting in my HOST_OS vlan, it cannot ping, or arp its gateway on the firewall.
The only drift from the design/ build detail is ive tried setting the vLANS to native. No joy.
Ive set the trunk t the firewall as LACP, no joy.
I'm not using any pinning -- tried this also, no joy.
- Danny
Walter.
02-23-2015 01:43 PM
Where im struggling, aside it not working! is being able to debug the configuration.
The output from nxos looks ok, to my untrained eye.
Is there anywhere short of from a built vNIC on a blade to run connectivity tests from, inside the Fabric on its command interfaces? It would be great to half the problem to concentrate debug efforts in a more targeted manner.
- Danny
02-23-2015 08:08 PM
02-24-2015 03:02 AM
HI Manuel,
Thank you for the reply.
I have tested between blade 3 and 4 and can confirm on the HOST_OS vNICs they can ping each other. This is in my vLAN 175.
Each Fabric has 1 Uplink, both to the same switch, which itself connected to a firewall that hosts the gateway IPs.
I think I have a spanning tree problem - both of my 10GB uplink ports are showing as blocked on the switch. I can't swear this was the case yesterday, my debug efforts may have triggered this, but certainly i need to clear the block first!
- Danny
02-24-2015 04:00 AM
Walter, Manuel
It is alive! ;)
Turns out, amazingly my original configuration with No LAN Pinning, No port channel, No trunk from the switch to the FI's was working.
My testing on Blade-2 was a poor choice, the blade was stuck at 84% configured, which I did not notice till today drilling around the GUI, after trying to debug why 3 to 4 could talk to each other but not to 2.
Removing the trunk/channel/pinning all sprang into life for 3 and 4 to reach their Gateways.
I'll rebuild Blade-2 from the template and hopefully all should be well
Thank you for your help
Danny
02-24-2015 08:00 AM
02-23-2015 02:23 PM
OK, not proud - but hopefully gives a flavour.
2 minute sketch of the Environment.
02-23-2015 11:13 PM
Hi Danny
Nice diagram ! can you add, which fabric A or B your vnics are connected to ?
Because mgt. and KVM are working (native vlan), something must be wrong with the trunk !
Therefore as Manuel suggested, try to ping 2 hosts, which are on the same vlan, and therefore L2 switched on the UCS FI.
Are all the vlans on the uplink trunk up ?
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/116095-configure-ucs-upstream-port-channel-00.html
UCS port channel configuration is statically set to Link Aggregation Control Protocol (LACP) mode active. This configuration cannot be modified; therefore, all upstream port-channel configurations must adhere to LACP mode active as well. Alternatively, you can configure the upstream switchports for LACP mode passive.
Here is a sample of the UCS interface configuration that cannot be modified:
UCS1-B(nxos)# show run interface eth1/19 !Command: show running-config interface Ethernet1/19 !Time: Fri Oct 12 20:25:59 2012 version 5.0(3)N2(2.11) interface Ethernet1/19 description U: Uplink pinning border switchport mode trunk switchport trunk allowed vlan 1,107,110-111,115,119, 168,175,179,183,200-201,279,283,379,383,555-556 channel-group 100 mode active no shutdown
02-24-2015 03:13 AM
I had no port channel configured at all, did not think id need this as only one physical uplink per Fabric to the switch.
I have now configured Port Channel on both a/1/3 and b/1/3 which are my uplink ports.
What I have now noticed, though cannot be sure if present yesterday, is both the 10GB uplink ports on the brocade switch are "blocked", so i suspect a spanning tree issue. Certainly needs fixing first!
Some output from the recommended tips,
* NXOS queries around trunk ports, shows vLANS assigned
* Brocade switch LACP configuration on my two uplink ports to the FIs
* VLAN for 168(KVM working) 175(HOST_OS not)
* Interfaces showing there is likely a ST issue.
Thanks Danny!
FI - NXOS - A: Trunk Queries !Command: show running-config interface Ethernet1/3 !Time: Tue Feb 24 13:29:55 2015 version 5.2(3)N2(2.23d) interface Ethernet1/3 description U: Uplink pinning border switchport mode trunk switchport trunk allowed vlan 1,168-177 udld disable channel-group 1 mode active no shutdown !Command: show running-config interface port-channel1 !Time: Tue Feb 24 13:35:58 2015 version 5.2(3)N2(2.23d) interface port-channel1 description U: Uplink switchport mode trunk pinning border switchport trunk allowed vlan 1,168-177 speed 10000 port-channel1 is up Hardware: Port-Channel, address: 002a.6afb.362a (bia 002a.6afb.362a) Description: U: Uplink MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA Port mode is trunk full-duplex, 10 Gb/s Input flow-control is off, output flow-control is off Switchport monitor is off EtherType is 0x8100 Members in this channel: Eth1/3 — Switch LACP Configuration: ICX6450-24P Switch>show link-aggregate ethernet 1/2/1 System ID: 748e.f8b1.a2e0 Default Key: 2 Port [Sys P] [Port P] [ Key ] [Act][Tio][Agg][Syn][Col][Dis][Def][Exp][Ope] 1/2/1 1 1 10000 Yes S Agg Syn Col Dis No No Ina ICX6450-24P Switch>show link-aggregate ethernet 1/2/3 System ID: 748e.f8b1.a2e0 Default Key: 2 Port [Sys P] [Port P] [ Key ] [Act][Tio][Agg][Syn][Col][Dis][Def][Exp][Ope] 1/2/3 1 1 10000 Yes S Agg Syn Col Dis No No Ina — Switch VLAN 175 and 168: PORT-VLAN 175, Name HOST_OS, Priority level0, Spanning tree On Untagged Ports: None Tagged Ports: (U1/M1) 1 Tagged Ports: (U1/M2) 1 3 Uplink Ports: None DualMode Ports: None Mac-Vlan Ports: None Monitoring: Disabled PORT-VLAN 168, Name HW_MGT, Priority level0, Spanning tree On Untagged Ports: (U1/M1) 3 4 Tagged Ports: (U1/M1) 1 Uplink Ports: None DualMode Ports: None Mac-Vlan Ports: None Monitoring: Disabled Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name 1/1/1 Up Forward Full 1G None Yes N/A 0 748e.f8b1.a2e0 1/1/2 Down None None None None No 1 0 748e.f8b1.a2e1 1/1/3 Up Forward Full 1G None No 168 0 748e.f8b1.a2e2 1/1/4 Up Forward Full 1G None No 168 0 748e.f8b1.a2e3 ......... ....... 1/2/1 Up Blocked Full 10G None Yes N/A 0 748e.f8b1.a2f9 1/2/2 ERR-DIS None None None None No 1 0 748e.f8b1.a2fa 1/2/3 Up Blocked Full 10G None Yes N/A 0 748e.f8b1.a2fb 1/2/4 ERR-DIS None None None None No 1 0 748e.f8b1.a2fc mgmt1 Down None None None None No None 0 748e.f8b1.a2e0
