03-22-2013 07:20 AM - edited 03-01-2019 10:56 AM
After upgrading to 2.1(1b) I noticed a new entry when creating your dynamic vNIC's/templates (see attached pic). How is this different from the previous implementation of the firmware?
Solved! Go to Solution.
03-22-2013 07:24 AM
It's just a cleaner way to separate the Dynamic vNICs from regular vNICs. Previously they were grouped under the same tree. This is a cosmetic change only.
Robert
03-22-2013 07:25 AM
Hi Mike,
With 2.1 we support SRIOV under which the vnic also called physical funtion can now have multiple VF i.e. virtual functions. This dynamic list is the place holder for those VF.
./Abhinav
03-22-2013 07:24 AM
Robert
03-22-2013 07:25 AM
Hi Mike,
./Abhinav
